Oil cooler adaptor sandwich plate.... http://forum.triumphdolomite.co.uk/viewtopic.php?t=33968 |
Page 1 of 2 |
Author: | shaunroche [ Tue May 15, 2018 10:58 pm ] |
Post subject: | Oil cooler adaptor sandwich plate.... |
Hi chaps, I'm looking at fitting an oil cooler sandwich plate with built in thermostat to the Sprint and I'm confused as to how they fit. I understand it fastens on to where the oil filter goes, but how? I can't see that the STD oil filter goes onto it....I currently have a spin on filter adaptor on there ( they're crap etc. but I'm struggling to get paper filters and the club hasn't stocked them for months....) so, using a spin on adaptor, is the order, sandwich plate, filter adaptor, filter or is it sandwich plate then filter minus the adaptor or adaptor, sandwich plate, filter? Can't see any decent pics so struggling a bit...for a change! Cheers fellas! |
Author: | soe8m [ Tue May 15, 2018 11:08 pm ] |
Post subject: | Re: Oil cooler adaptor sandwich plate.... |
The oil cooler take off is a specific slant part. You take of the transfer plate, the part where the oil pressure switch is in, and replace that plate by one that doesn't transfer but has two outlet unions. It's not an inbetween filter part. I believe mocal does sell them. Jeroen. |
Author: | Mad Mart [ Tue May 15, 2018 11:16 pm ] |
Here's the one that replaces the transfer plate... |
Author: | xvivalve [ Tue May 15, 2018 11:18 pm ] |
The chap I referred you to with the oil cooler for sale had the adaptor, pipes and cooler |
Author: | gmsclassics [ Wed May 16, 2018 8:24 am ] |
Looks like that type isn't recommended for the Dolomite / TR7 / Sprint. As it fits between the filter and the block, maybe there isn't room? http://www.mocal.co.uk/products-octakeoffs.html They have listed the type Martin shows above, and I have fitted in my race car. Can send / post photos of the full installation if that helps. Geoff |
Author: | shaunroche [ Wed May 16, 2018 8:33 am ] |
The 'A' type there Geoff, I assume that fastens straight to the block, so then does the filter fasten to that or do you still need the filter (spin on) adaptor do you know? I have a side adaptor plate but was trying to avoid having a separate thermostat..... |
Author: | Mad Mart [ Wed May 16, 2018 11:15 am ] |
I was always taught not to bite the hand that feeds you. |
Author: | shaunroche [ Wed May 16, 2018 11:31 am ] |
You'll have to spell out what you mean Martin.
Author: | xvivalve [ Wed May 16, 2018 12:05 pm ] |
Thinking aloud...: Can the sandwich plate be used between the block and the transfer housing cover to achieve what you want? There are three galleries in the transfer housing and only the one in the filter housing, but there's only the one in the transfer housing cover (to link two of the three), so were it aligned correctly...? |
Author: | soe8m [ Thu May 17, 2018 8:38 pm ] |
The one in your pic fits on an spin on engine so you need the adapter. You end up with an oil filter adapter adapter spin off. Jeroen |
Author: | PaulB [ Wed Jun 06, 2018 6:17 pm ] |
Why you struggling to get paper filters? They are easy to get, a shop near you stocks them...... Regards, Paul. |
Author: | shaunroche [ Wed Jun 06, 2018 8:00 pm ] |
I am never sure which the correct ones are as I thought there was some controversy over a NRV or something so don't trust the Halfords ones. Regards, Paul. I've binned the thought of a sandwich plate now anyway as I don't think it'll fit over the steering rack. |
Author: | xvivalve [ Wed Jun 06, 2018 9:06 pm ] |
The controversy was (and remains) the end plates need to have a raised metal ring around the central hole. Those that have this made of a glued cardboard ring have a history of letting go of the cardboard ring that then clogs the filter. |
Page 1 of 2 | All times are UTC+01:00 |
