It is currently Fri Apr 19, 2024 8:55 pm
PostPosted: Thu Jun 14, 2018 11:37 am
Missing 3 of the white round screw grommets for the screws to hold front grills in place on my Toledo, Are these still available or can anyone recommend a replacement? One side was held on just with zip ties.
Cheers Rich
1981 Dolomite 1500 Auto
PostPosted: Thu Jun 14, 2018 11:55 am
TDC Staffs Area Organiser
Are these similar to the Dolomite setup? If they are then I used plastic number plate screws. Easy to obtain and don't rust. You don't have to use those u clips either.
PostPosted: Thu Jun 14, 2018 12:13 pm
Bresco do the white plastic screw retainers for this, original part number is 621535, there are 10 in all.
I might be able to find a few decent used ones if you get stuck!
PostPosted: Thu Jun 14, 2018 12:40 pm
Where are the other 2 then Steve? Have the four one side and one the other hence why I thought I was missing 3, grills are in bad condition so have some replacements all intact, so guessing the 2 others are the long screw ways which are not on the set I've removed?
Rich
PostPosted: Thu Jun 14, 2018 12:56 pm
Rich
Yes that's right, the odd 2 go in the long tubes at the outside ends of the grilles. Finding screws for these is a right pain, mostly they are missing, with the tubes broken off and often the bit of front inner panel they fit to is missing as well! Fortunately 4 a side is generally sufficient, so I regard the end ones as optional!
Users browsing this forum: Google and 75 guests
