It is currently Fri Apr 19, 2024 12:59 am
 Post subject: sloppy gear change
PostPosted: Fri Jun 22, 2018 4:35 pm
my 1500 fwd is hard too get into first and reverse - there's not much distinction between the respective gear slots. any ideas what could rectify that to make the gear selection more defined? thanks
 Post subject: Re: sloppy gear change
PostPosted: Fri Jun 22, 2018 4:41 pm
Bushes at the bottom of the gear shift would be my first point of call
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
PostPosted: Sat Jun 23, 2018 11:41 pm
Online
What Bruce said!^^^^^^^^
The FWD box will never have the precision of a RWD box, but you should be able to find the gears OK! There are a set of nylon and rubber bushes and little metal tubes that all wear in the bottom of the stick/linkage, some are the same as used in the Heralds/Spitfires 3 rail box. You can still get a kit for the Herald linkage from all the usual suspects.
PostPosted: Tue Jul 03, 2018 6:46 am
hi i've bought what i think is a bush its a thick black rubber circle about the size if a £2 coin. would this be it? alos, is this accessed from inside the car by taking the carpet cover off the stick? thanks
Users browsing this forum: No registered users and 39 guests
