It is currently Mon Nov 19, 2018 10:02 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Sun Jul 01, 2018 7:49 pm
I use a small metal bar and G clamp, holding it by hand won't work.
PostPosted: Mon Jul 02, 2018 2:19 pm
So I got my new Slave and upon attempted fitting there is a problem. The thread where the clutch pipe screws in is Considerably smaller than the original (I'm guessing) That I took off. Been to Pirtek and Hyphose but they had nothing that would work..any suggestions?
1981 Dolomite 1500 Auto
1971 Toledo 4 door
PostPosted: Mon Jul 02, 2018 2:20 pm
Original is 7/16 and new one 3/8 UNF.
Cheers Rich
1971 Toledo 4 door
PostPosted: Mon Jul 02, 2018 2:41 pm
Try a brake pipe fitting in there Rich :)
PostPosted: Mon Jul 02, 2018 2:50 pm
Hi Tony, Only problem is that with the curvature on the clutch pipe, if you cut the flare off to re-flare with another union, there's not enough pipe to be able to get a flaring tool on it!
1971 Toledo 4 door
 Post subject: Here you go........
PostPosted: Mon Jul 02, 2018 5:14 pm
https://www.carbuildersolutions.com/uk/ ... unf-female
Ian
 Post subject: Re: Here you go........
PostPosted: Mon Jul 02, 2018 5:20 pm
PostPosted: Mon Jul 02, 2018 6:51 pm
I bought this earlier but thread isn't long enough as screws all the way into slave with no resistance so no seal in all likelyhood! Thread length on this is 10mm but that's just the thread.
Will message or phone them tomorrow to see if I can get more precise information. Thanks for the link Ian :thumbsup:
1971 Toledo 4 door
 Post subject: Aye....
PostPosted: Tue Jul 03, 2018 2:41 pm
You need a copper washer to form the seal between the cylinder and the adapter.
 Post subject: Re: Aye....
PostPosted: Tue Jul 03, 2018 4:10 pm
Have ordered the adaptor from cbs, hopefully will be sorted when it arrives.
Cheers Rich
1971 Toledo 4 door
PostPosted: Wed Jul 04, 2018 6:07 am
Next time we’ll check everything AND the Union thread size! Evidently the numbers are the casting number and bore, but not the part number....
PostPosted: Wed Jul 04, 2018 2:39 pm
No problem Alun, think I'm almost sorted now, and will still be better than some of the remanufactured ones which are failing after short periods.
:thumbsup:
Rich..
1971 Toledo 4 door
PostPosted: Wed Jul 04, 2018 2:58 pm
Adaptor arrived from Car Builders solutions this morning, looks like it will work but haven't got a copper crush washer that small! I do however have a Hydraulic Dowty washer in this size, do you think it will seal ok?
Rich..
1971 Toledo 4 door
PostPosted: Sat Jul 07, 2018 12:07 pm
Plan on fitting and bleeding and hopefully using the car tomorrow, I have a copper washer or a Dowty seal, which should I use as only want to do it once? Anyone used these hydraulic seals before for car stuff?
Thanks Rich
1971 Toledo 4 door
PostPosted: Mon Jul 09, 2018 7:28 pm
So fitted and bled the new slave..bled perfectly and installed with a lot of persuasion and Bruce's guidance, only to discover that there is still not enough travel in the pedal. Master cylinder repair kit is the next port of call. Reason for the replacement of the slave was that it was so corroded into the housing on the cap and when I finally managed to free off the cap the piston was definitely stuck in the bore! Also removed master at the same time slave was removed and everything seemed to be moving freely but something amiss somewhere!
Rich..
1971 Toledo 4 door
