It is currently Fri Apr 19, 2024 5:04 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
 Post subject: Re: Millers CSS 20W/60
PostPosted: Tue Jul 10, 2018 12:09 pm
TDC Motorsport Registrar
Out of interest, how do you think the quality of oil today compares to that from 50 years ago when these engines were first cobbled together?
Quality / viscosity. Different things
+1
Personally I do not think that the 1850/Sprint engine was 'cobbled together', I think that they were very well engineered by some very talented people. I would suggest that if you need to use a high viscosity oil to maintain pressure that you should be looking to rebuild your engine rather than mask the problem.
Yes, exactly that, cobbled together. Wasn't this the very reason the car was never called the 135 because they couldn't manage to build engines to a consistent standard?: and just like when I removed the cills, one side had red lead inside, the other was bare metal.
My engine was built by Trackerjack and has done 2000 miles, I'll let him know you're calling his abilities into question! ;)
And btw, the engineering and design of the engine isn't being brought into question, the building, manufacture and supply of the parts is.
Triumph was run by accountants not normal people...er.... I mean Engineers.
PostPosted: Tue Jul 10, 2018 1:01 pm
Don't care if Spen King himself built your engine! If you have to use a 20w/60 to maintain the correct oil pressure then there's something wrong with it.
What's the correct figures, back of a fag packet thinking 30psi idle then 10psi per 1k RPM when hot?
PostPosted: Tue Jul 10, 2018 1:08 pm
Hehe, made me smile that!
 Post subject: Hmm......
PostPosted: Tue Jul 10, 2018 2:09 pm
I think that slant fours should be about 45psi at running speeds?
Somewhere in service notes I am sure I have read that.
Anyhow I can confirm that the oil pressure relief valve is 54 to 60 psi
(page 12.60.32 sheet 3 BL 1850 workshop manual (AKM3628A)).
Users browsing this forum: Google and 39 guests
