Nut 143804 - Toledo front suspension
http://forum.triumphdolomite.co.uk/viewtopic.php?t=34394
Author:  2door-toledo [ Thu Sep 27, 2018 1:35 pm ]
Post subject:  Nut 143804 - Toledo front suspension
Hi,
I'm replacing all of the fasteners on my Toledo's front suspension. I'm having trouble finding a source of nut 143804 (lower right in image). Does anyone know how it differs from 143802 and if I can use this instead? 143802 is offered by certain suppliers and I believe that is a nyloc 5/16 " UNF x 1/2 ".
Thanks.
Author:  Galileo [ Thu Sep 27, 2018 2:36 pm ]
Post subject:  Re: Nut 143804 - Toledo front suspension
Originally Cleveloc not Nyloc nuts to be pedantic! 3/8 UNF, have you tried looking around the Triumph range, same fasteners were used all over the place, this any good as a suggestion? https://www.revingtontr.com/product/ny6 ... 5-32-thick
Author:  2door-toledo [ Thu Sep 27, 2018 3:17 pm ]
Thanks for the reply - that's very helpful and helped me to understand that despite spending many hours looking at this page of the parts book I was misunderstanding the diagram entirely! I can now see that it goes onto the end of HB926 which as you say is 3/8" so your suggestion makes perfect sense.
Thanks!
Author:  TrustNo1 [ Thu Sep 27, 2018 8:08 pm ]
Originally Cleveloc not Nyloc nuts [/url]
Is there any benefit to using Cleveloc over Nylock , I've been using Nylocks since I ran out of Cleveloc?
Author:  Galileo [ Thu Sep 27, 2018 8:35 pm ]
Only if there's any heat about, I've only ever used them on propshafts myself.
Author:  TrustNo1 [ Fri Sep 28, 2018 8:22 pm ]
Ah good point I'd not thought about heat cheers
Page 1 of 1 All times are UTC+01:00
https://www.phpbb.com/
