It is currently Mon Dec 10, 2018 5:56 pm
Post new topic  Reply to topic  [ 42 posts ]  Go to page 1 2 3 Next
PostPosted: Sat Dec 08, 2007 4:53 pm
Hi Folks,
Have been stripping my front suspension today so that I can re-bush it - but the damn pivot bolt that connects the lower wishbone to the mounting bracket was stuck fast so I had to cut it off.
Trouble is that Rimmers list this part as 'no longer available' (part 216901) - does anyone know there I can get one, or whether there is a suitable alternative? (or is there something special about this bolt?)
My best guess so far: the front shock absorber lower mounting bolts seem similar (BH606201) but would need the threaded length extending.
Any advice from the gurus?
Cheers,
Mark.
 Post subject:
PostPosted: Sat Dec 08, 2007 4:58 pm
Take the other side one out and go to Swansea Fasteners, they do Imperial stuff too
Triumphless! Infact completely car-less!
 Post subject:
PostPosted: Sat Dec 08, 2007 7:04 pm
I have some s/h ones...
 Post subject:
PostPosted: Sat Dec 08, 2007 7:07 pm
you could try mick dolphin? he is always very helpful
Ben
1967 Triumph Vitesse in signal Red
1980 dolomite 1850 HL russet
2004 MG ZT
TDC member !
 Post subject:
PostPosted: Sun Dec 09, 2007 10:33 am
TDC Events Officer
You mean that really long one? I soaked it in wd 40 for a week (more WD every evening) then used a 2' breaker bar on one end, and the other end a large ratchet wedged under the subframe. I think I only had to jump on it a few times before it came loose...
I'd quite like to renew mine if a supplier does come up, I can't think it would have liked that sort of abuse too much.
 Post subject:
PostPosted: Sun Dec 09, 2007 11:19 am
I bought some brand new ones from Fitchetts in the summer.
 Post subject:
PostPosted: Sun Dec 09, 2007 11:36 am
quick trip over to 'swansea' fasteners enterprise zone by ashmoles fiat alfa dealers
 Post subject:
PostPosted: Sun Dec 09, 2007 3:10 pm
The bolt is an ordinary bolt afaik but with a slightly thinner head. Pt. No. 216901
2007 Porsche Boxster S
Grammar:
Schedule: Pronounced "Shedule" not "Scedule"!
 Post subject:
PostPosted: Sun Dec 09, 2007 4:14 pm
Its not on that diagram Mart; its the long one which passes through the upper wishbones at extension of the sbframe...
 Post subject:
PostPosted: Sun Dec 09, 2007 4:56 pm
mark said lower wishbone bolt, however the bottom arms arent wishbones though.
mart can you whack up diagram for the top part of the suspension and mark can tell us the number he means
:wink:
daytona 675 (a proper fast triumph)
rover 220 coupe turbo - press car, 1st one reg'd on road
Passat 2.0 TDI
now a very meagre offering of doloparts FOR SALE/to clear
 Post subject:
PostPosted: Sun Dec 09, 2007 5:38 pm
He did also say that it looks similar to the bottom front shock bolt....... so I think the one you have stated Mart is the one.
'74 Magenta Sprint WDY250M
 Post subject: Easy to locate....
PostPosted: Sun Dec 09, 2007 6:28 pm
The part number Mark quoted is for the track control arm bolt. These are a standard UNF size and are available from motor factors or agricultural machinery suppliers.
The shoulder length (unthreaded bit) is important in this application - do not use a machine screw (threaded up to the head) even if it is the same overall length.
 Post subject: unf bolt
PostPosted: Sun Dec 09, 2007 6:57 pm
Hi ,let me know the size and I am sure we will have one in stock.Is it a nut and bolt ? if so ,why cant a metric equivilant do?
cheers
1977 DOLOMITE SPRINT
1971 MGB ROADSTER
 Post subject: Re: unf bolt
PostPosted: Sun Dec 09, 2007 7:06 pm
cheers
A metric size is not suitable because the diameter will be different, eg for 3/8"UNF applications M8 is too small and M10 too big.
 Post subject:
PostPosted: Sun Dec 09, 2007 7:44 pm
Call these guys. I have used them to replace several bolts on my car including the exhaust manifold to head bolts. They are pretty cheap too compared to Rimmers. http://www.margnor.co.uk/=contact.htm
If they won't post or take cards, let me know, I'll pop in and get them for you and post them on.
Users browsing this forum: clubbyal79ch and 1 guest
