It is currently Tue Apr 16, 2024 8:08 am
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 Next
PostPosted: Sun Oct 19, 2014 9:26 pm
Basically this just me ranting about the French and how they seemed determined to torture home mechanics. Had to replace the radius arm bearings in the xantia, fair enough, it has done 210000 miles. The problem was little design decisions that made the job harder.
A good example is the gaitor retainer. It is held on by a circular clip held in by a a screw you remove with a socket. Perfectly sensible design. Then why hide it in a place no spanner an reach? If they put it on the other way round, it would have been easy. The damn car is full of bolt, clips, and screws placed in the worst possible place for access. Honestly, for all its faults, the Dolly is easy to work on in comparison.
So what is the hardest car to work on? My guess, the French made it.
PostPosted: Sun Oct 19, 2014 10:29 pm
A friend and I had problems replacing the rear brake shoes on his Renault 5, for similar reasons.
PostPosted: Sun Oct 19, 2014 11:57 pm
You will struggle to find cars worse than the French ones!
Pug 205, if you want to remove rear seat the bolts are too long and go through floor and start to undoe.............until you get to the rusty bit that was too long, so they break off.
Try sorting the fuel pump out and you will find the earth wire.................in the back light????
Even a simple job like brake bleeding :cry: alloy calipers and tiny bleed nipples = broken nipples :evil:
Buy Jap or German.
PostPosted: Mon Oct 20, 2014 4:03 pm
Latin - french and italian - cars are rather like their women...
You wouldnt want to get old with one....(with a couple of notable exceptions like the Lambo Miura)
But the I guess that's talking film stars. Your commodity waitress or barmaid is a different thing altogether
and that's where your Reanut 5 and 205 Laguna and Xantia etc come in - barmaid cars.
German and Swedish cars are a different thing altogether....much like their women who dont seem to go down hill
any faster that dolomites do.
PostPosted: Mon Oct 20, 2014 7:49 pm
You mean they are not trying to run away from you as they might have done when they were a bit younger? Not teasing you any more? Not wearing their mini skirts? The mind boggles.
PostPosted: Mon Oct 20, 2014 8:10 pm
The Renault Laguna I serviced earlier on this year wasn't too bad apart from the sump plug. I had to borrow a special socket to get it undone. As for the fuel filter, forget it. It is integrated with the fuel pump.
PostPosted: Mon Oct 20, 2014 10:27 pm
Every French car has "Remember Waterloo" inconspicuously stamped on the underside!
We made the b****rs bleed there and Renaults are their revenge! All French cars are a design nightmare but IMO Renault are the worst. I recently had to remove the engine and gearbox completely to change the sump gasket on a Clio and the alternator is almost as bad.
My theory is that they get the bare block installed in the engine bay, then get all the ancillary bits in a big cardboard box, upend it over the engine and bolt everything on where it falls!!! That's why you always have to take something else (or several somethings) off to get at what you want!
PostPosted: Tue Oct 21, 2014 11:33 am
You're not joking there! My friend has a 2007 Megane convertible - the fuse box in the is upside-down (as the previous model used to fill with water) and to replace a fuse in it you have to remove the battery, ECU and tons of ducting, wiring, etc. terrible!
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
PostPosted: Tue Oct 21, 2014 1:11 pm
MGF
I hate working on the damn things. Everything is difficult.
PostPosted: Tue Oct 21, 2014 2:17 pm
Ah yes, the wiring. Had to replace a door, got the scrap yard to take the old one off. He confessed he cut the loom, he couldn't find the multiplug for the door, it was like they plumbed in each wire seperately.
PostPosted: Tue Oct 21, 2014 2:18 pm
MGF
My father has one of those, the engine looks like a nightmare to work on. You have to access everything through what is basically an oversized letterbox.
PostPosted: Wed Oct 22, 2014 11:13 am
You can flip the hood forward, and theres a bolted in access plate beneath to access the top of the engine. Adds half an hour on to anything needing decent access to the engine. Theres another plate on the cambelt side of the inner wing to get at the belts, but, yes, its basically like working through a slot. Alternator and clutch swops are especially horrible. And being a 90s Rover product every fixing and fastener will be rusty, siezed.... Then theres the ridiculous hydrogas suspension, ok on a 60s family car but a 90s sports car? Yuk. The whole car is basically a bodge up made from components that were obsolete i.e. Metro subframes... The rear end still has trackrod ends and a towing eye from when the same setup was used in the front of a Metro. I shudder when when of these things comes to me for work, try and avoid them if i can..
PostPosted: Wed Oct 22, 2014 8:45 pm
If you think an MGF is bad, you should try a Lotus Elise! Its just like an F, (some even have the K series engine)
but not as well put together and with even worse access! And if you think engine access is bad on an F, don't even think about trying to change the heater matrix. I did one that was necessitated by the ubiquitous head gasket failure, it took me 4 days and involved removing EVERYTHING from the cockpit from the board behind the seats to the entire dash and steering column.
PostPosted: Thu Oct 23, 2014 7:37 am
My mate took on an MGF, it broke him!! Don't get me wrong, he wasn't an experienced mechanic, but he's not a cack handed hammer wealding clown either. You need three hands with foot long rubber fingers to work in the guts of those things. Love it!!!
PostPosted: Thu Oct 23, 2014 12:16 pm
Never touched an Elise, but i owned an Excel for a while, and have worked on Esprits and M100 Elans fairly often. Some jobs can be awkward - Esprit cambelts are especially "fun", but at least you can get some enjoyment working on it from it being a "special" car. Not something you can say about an MGF. I always enjoyed working on Lotuses, even supposedly awkward jobs like door beams on the Excels, which need shimming in every direction. Would take on any job on an old Lotus over the same job on an MGF any day!
Matt.
Users browsing this forum: DotBot [Bot] and 7 guests
