Good bargain except I'm having trouble getting it to work.
It seems to have wire colour codes unlike any other listed on the various Internet sites.
There are 3 wires coming out of it plus the coax with the new style R.F. connector.
The coax is nicely earthed and checks out as 0 ohms with the voltmeter.
The control 3 wires are........
BLACK. I reckon this should be earthed to the car body earth . And this check out as connected O.K. with a needle-probe.
This leaves a RED wire fused at 5A. Fuse is O.K. but shows no continuity to earth or the BLUE wire.
And a BLUE wire , unfused which shows a resistance of 230 ohms to ground.
Putting +12V on this BLUE wire makes the aerial give a click as if a relay is operating, but nothing else.
Putting +12 V on the red wire does nothing.
Now the radio had a 3 wire control from a relay.
RED, which goes to +12 V always live but goes to 0V when the radio is on.
BLUE, which goes to +12 V when the radio is turned on.
There is also a yellow wire that connects to ground when the radio is on.
Intuitively I suspect RED to RED, BLUE to BLUE and ignore the yellow.
But since I can't get the aerial to work with a +12V wander lead I think it may be dead .
Any ideas please folks ?
Ta,
