Thanks for replying
There should be a switch on the side should you trip it out.
There must be an auto trip installed because there is no switch on my model, despite clearly showing a circuit breaker trip in the picture of the PPX on the packaging.
The negative is used the same as the positive, you can use it if you need to provide an earth for someting, or as i did the other day i powered up the lights on a TR4 as its positive earth.
So am I correct in assuming that if one of the components has a bad ground, I can connect the PPX up and press the 'negative' power button to supply a new ground and the item will power up?
