Well since I last updated I have painted the radius arm bracket etc black, and then put underseal on the underside. It doesn't look pretty but I just want to make sure it doesn't rust again. You wont see this anyway under the carpet so not to worry. Also welded up the other hole near the rotoflex mountings.
I have oiled my trunnions at the front, and checked my wheel bearings and everything seems to be OK.
Looks better than it was before, I'm very happy with this!
I started painting the bonnet too and it's looking more like a car again. I am really happy with the fitment of the bonnet, aswell as the fitment of my valances which I tested today! Those valances are fibreglass aswell and cost me 99p on the Bay
;D
Also test fitted my bonnet latches which I'm happy to say also fit well.
I also welded up the sheet metal inner of the rear quarters from inside the boot as when I did it, it hadn't been very strong as i'd struggled with the leaning over welding and lack of light. I proceeded to then put tetra schutz on the areas where I have welded (front bulkhead, rear radius arm, boot, inner sills) will this be OK? I had zinc primed first but I felt this just completely sealed any pinholes etc which existed. Was I wrong to do this?It's put my mind at ease really as it's one less thing to worry about and looks much better.
