It is currently Tue Apr 16, 2024 6:53 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page 1 2 3 Next
 Post subject: modern clutches
PostPosted: Sat Dec 19, 2015 7:26 pm
My Mitsubishi Colt made a strange brief chattering noise a couple of times today and the clutch pedal became a bit juddery, so I drove it straight to my local garage where they diagnosed it as the clutch or the flywheel.
As I was puzled, the guy explained that modern cars have combined clutch and flywheel assemblies and "run through grease". What on earth does this mean? The only clutch I've ever changed was on a 1500HL. My car's not even that modern, it's on an 06 plate. Anybody got any experience of what he's on about?
Alan
 Post subject: Re: modern clutches
PostPosted: Sat Dec 19, 2015 7:40 pm
Ah, the dreaded dual mass flywheel! Many years ago, Mr Borg and Mr Beck invented the friction clutch (if not them, then someone similar) The idea was so good that cars have used the same design for about 70 years. This design included springs in the drive plate to act as shock absorbers on take off.
Then a few years ago, some motor manufacturers looked at this design and thought " this is simple and effective and relatively cheap and easy to work on - we must do something about it!"
The result of their meddling is the dual mass flywheel and basically what it does is take the springs from the drive plate and put them into the (now two piece) flywheel, thereby making what was a lifetime part into a frequent (and expensive) service item which imparts little or no improvement to drive quality.
Now you know!
PostPosted: Sat Dec 19, 2015 8:07 pm
Thanks Steve. Do you ever get that feeling that you'd rather not know...
PostPosted: Sat Dec 19, 2015 10:19 pm
Hi Alan,
I have just had my first hands on experience of one of these on my daughters Audi A3. I have replaced it with an old style flywheel, plate, cover & new thrust bearing. The cost of the conversion kit was about half that of a replacement dual mass flywheel. Only real problem I had was getting access to the flywheel bolts as the one half of the flywheel had twisted and stuck with the access holes now out of line with the bolts. Half an hour with an angle grinder and cutting disc sorted it though.
Best of luck
Chris
PostPosted: Sun Dec 20, 2015 8:29 pm
TDC Staffs Area Organiser
DMF's are really designed to reduce unwanted transmission wear and also aid refinement. They also enable much better low speed driveability. I've known some people to swap out to a solid flywheel in Ford Focus and it's just made it drive and feel like a van.
Yes DMF's are a pain and expensive but cars are much nicer with them.
PostPosted: Mon Dec 21, 2015 9:25 am
I will admit that a DMF improves a diesel slightly but on petrol cars which run smoother at low revs the improvement is negligible.
Most of the Kidderminster Taxis are Toyota Avensis' These are all converted to solid flywheels as soon as the DMF fails and no drivers have complained even though they are driven all day every day and mostly in traffic.
PostPosted: Mon Dec 21, 2015 10:34 pm
A colleague of mine that used to work in the Post Office MT told me they just welded them up.
Trevor
2017 Jaguar XE R-sport
PostPosted: Tue Dec 22, 2015 10:22 pm
I would be warry of putting a solid flywheel on a car designed for DMF. All the extra vibration could do damage elsewhere. They weren't designed for a solid flywheel.
PostPosted: Tue Dec 22, 2015 11:34 pm
When you fit the solid flywheel, you also change the clutch for one with springs in the drive plate. It's a complete package and designed for the job! I have seen a few DMFs welded up, its not easy to do it well enough to keep it in balance and there are no springs to cushion the drive shocks so drive plates and transmissions suffer early failures as well as making the clutch "agricultural" to say the least, the people I know who've done it have sold the vehicle on immediately.
PostPosted: Thu Dec 24, 2015 2:10 pm
My dad has just replaced the dmf on his Focus and showed me the old one earlier. It had totally failed with a huge amount of play in all directions. He's always been paranoid about it so had driven like a saint but clearly after 60k it's had enough regardless.
PostPosted: Fri Dec 25, 2015 1:05 am
I've changed a Focus (diesel) DMF at 35k and another at 170k. The low mileage one was a tidy and well cared for 1 owner example, the high mileage one was a thrashed and tatty shed -you do the math!
But a word to the wise, with a DMF equipped car it is very bad to sit in traffic in gear with the clutch depressed - something about overheating the DMF has been mentioned bringing on premature failure.
I drive a DMF equipped Zafira diesel on a weekly basis, I'm almost the only driver and the car is now on 172k and still on its original DMF (I know both owners from new) Even with me doing it, the owner would face a bill for about £1100 if it fails which would write the car off so I baby it!
PostPosted: Fri Dec 25, 2015 9:14 pm
But a word to the wise, with a DMF equipped car it is very bad to sit in traffic in gear with the clutch depressed - something about overheating the DMF has been mentioned bringing on premature failure...........
Thanks for that, I'll change that aspect of my poor driving habits immediately. :)
PostPosted: Sat Dec 26, 2015 2:17 pm
Bug bear of mine- when the car is at rest apply the handbrake, very simple, handbrakes are far cheaper than clutches.
Trevor
PostPosted: Sat Dec 26, 2015 4:35 pm
Explains our company van, Merc Sprinter.
£1645+vat, new dmf, new clutch and sundries.
PostPosted: Sat Dec 26, 2015 8:01 pm
And don't even THINK about holding it on the clutch on a hill!
This is one thing that a DMF does make easier, but if you value your wallet, DON'T DO IT!
Users browsing this forum: No registered users and 8 guests
