When you say theres no flow to the rad - what do you mean? Is the car overheating or are you just worried because the radiators not getting warm to the touch? This time of year, with the heater on full, its not unusual for the rad to stay cold as the heater is taking all the heat out of the cooling system - in fact thats what the thermostat is designed to allow.
If its actually overheating thats different, personally id be looking at the waterpump next, its not an uncommon thing to fail on the little 1.2 Fiat engines, some of them have plastic impellers that fall off the shaft, and then you get no water circulation.
