It is currently Tue Apr 16, 2024 10:21 am
PostPosted: Tue Jan 10, 2017 4:46 pm
... and where can I get a socket to fit it please ?
It is about 44mm in overall diameter.
I tried Googling "circular nut" but this leads to angle grinder disc retainers.
Its a tail-gate lock on an MGBGT btw.
Thanks ,
PostPosted: Tue Jan 10, 2017 4:49 pm
Threaded retainer or locking collar :?
PostPosted: Tue Jan 10, 2017 5:41 pm
I always tighten them with a water pump pliers, or if there is no room for them, do it up finger tight and then tap round with a hammer and screwdriver.
PostPosted: Tue Jan 10, 2017 6:37 pm
Tail gate lock nut.
PostPosted: Tue Jan 10, 2017 6:49 pm
I'm going to guess it's just called a lock nut. Take a file to a standard socket? Or as Steve said, hammer and screwdriver.
PostPosted: Fri Jan 13, 2017 2:21 pm
Thanks All for your advice. I was looking at making up something by cutting slots in a piece of pipe as I didn't want to risk punching the bodywork, and water pump pliers were too large to get in.
I did notice that the internal bits and pieces were held in by a circlip. It was quite easy to remove this and just swap the lock barrel. And I didn't need to fit the gasket kit.
Sorted !
PostPosted: Fri Jan 13, 2017 8:49 pm
Threaded retaining ring.
Users browsing this forum: No registered users and 7 guests
