It is currently Tue Sep 25, 2018 3:18 pm
Post new topic  Reply to topic  [ 223 posts ]  Go to page Previous 111 12 13 14 15 Next
PostPosted: Mon Jan 01, 2018 7:05 pm
TDC West Yorks Area Organiser
The annual service was due so I went over to my local dealer and bought engine oil, oil filter, air filter, fuel filter and cabin filters (there are 2 of them). The total cost was just shy of £102 which wasn't bad for genuine Citroen parts. This should help with emissions come MoT time which is due on the 24th.
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the modern)
"There is only one way to avoid criticsm: do nothing, say nothing and be nothing." Aristotle
PostPosted: Sun Jan 07, 2018 7:54 pm
The MoT is booked for Wednesday (the 10th). I'm quite confident that it should pass (be prepared to watch me eat those words!). Last year it failed on 2 bulbs and I've done a lot of work on it since I bought it about a year ago.
PostPosted: Wed Jan 10, 2018 7:02 pm
Surprisingly it failed. What was more surprising was that it failed on the offside outer CV boot which was the same side that had a new driveshaft fitted. The boot had popped off so I got my local garage to replace the grease that had escaped and refitted the CV boot with a new clip and it passed the retest so that's all done and dusted for another year.
PostPosted: Wed Jan 10, 2018 7:25 pm
TDC Sprint Registrar
The plus points are
1. The car is consistant
2. It passed
PostPosted: Wed Jan 10, 2018 8:07 pm
The plus points are
2. It passed
And here the visual.
PostPosted: Wed Jan 10, 2018 9:56 pm
Mahesh did you know you can get yellow cv boots?! I didnt lol :)
PostPosted: Wed Jan 10, 2018 11:20 pm
Along with the matching cable ties and grease...
PostPosted: Thu Jan 11, 2018 8:37 am
TDC Staffs Area Organiser
Looks like mustard
2015 BMW 118d Sport
PostPosted: Thu Jan 11, 2018 10:06 am
TDC Cheshire Area Organiser
If you are using cable ties on the cv boot? I would check it every week :? As they are not good at all on cv boots :(
Cheers,
PostPosted: Thu Jan 11, 2018 12:38 pm
No cable ties involved. I've had a look at the offside outer CV joint (the one where the boot popped off) and it has been refitted with the correct type of clip.
PostPosted: Thu Jan 11, 2018 1:00 pm
Great stuff :D It has been done properly :D
Cheers, Tony.
PostPosted: Thu Jan 11, 2018 2:38 pm
I'm pretty sure Nigel (the tester) would have sulked a lot if it hadn't been done right!
http://yorkshire-spitfire.blogspot.com/
PostPosted: Thu Jan 11, 2018 10:36 pm
It was good enough for Nigel who saw fit to issue the MoT certificate so it is good enough for me.
PostPosted: Wed Feb 07, 2018 12:44 pm
Oh feck!
I had a blowout on the offside rear tyre on the way to work. I was on the motorway at the time and I didn't know that the tyre had failed until I had found a safe place to stop off the motorway. Because I didn't have a spare (most modern cars have a can of tyre sealant instead of a spare wheel) I had to get the RAC to recover me to the nearest tyre fitter. I had fitted Avon ZV7s to the front last year so I had a pair of the same tyres fitted to the rear costing me just over £200. A previous owner had fitted a full set of Nexens following the 2016 MoT (there was an advisory on tyres worn to the legal limit). As a result I was just over 4 hours late for work. I had my GoPro in the car at the time so I've got it on video.
PostPosted: Mon Feb 26, 2018 12:40 pm
Oh feck!
I discovered the the offside outer CV boot has split. I've been on to the motor factor that supplied the driveshaft and they will get it exchanged for me.
