It is currently Thu Jul 19, 2018 6:58 pm
 Post subject: shot blasting barrel
PostPosted: Thu Apr 26, 2018 3:57 pm
hi all
look at what i made.....and it works.....waterbutt 212 litre.....21" diameter by 39" long
using a canister gun with 0.5mm to 1mm glass shot media,wheel came out alright,but this is working at 45psi
just need to sort out the air line input hole
thanks nic tt
Dolomite 1300,1980`V`reg in british racing brown(russet),3.63 diff with 21t speedo pinion,95%poly`d,HL clocks,standard wheels with SE covers wrapt in 175 70 13,mot`d 19-09-2014,been off the since 1990,(july2017) stainless steel exhaust 3-piece.
Dolomite 1300,1977(tax free 1-1-1977),`R`reg in carmine red,bog standard including rust :shock: last time on road 6-2005
 Post subject: Re: shot blasting barrel
PostPosted: Thu Apr 26, 2018 6:36 pm
That's excellent, have you put lighting in it?
PostPosted: Fri Apr 27, 2018 6:45 am
yeah got lighting in,,,12v 30led ultra bright,only cabled tied in until i find the correct overall light position
PostPosted: Sat Apr 28, 2018 1:00 pm
That's great, I've been using a large wooden box.... goes looking for a plastic barrel :)
PostPosted: Tue May 01, 2018 4:59 pm
blasted a pair of front shock mounts today,left is before-right is after
PostPosted: Fri May 04, 2018 5:58 am
Looks good, excellent work
1995 Trusty Peugeot 306 XND, no turbine, 227K miles young.
1997 Trusty Peugeot 306 GLX TD, 90K miles and soon to ride again..
Alfa Romeo 147 1.9 JTD 150 Ti Lusso , no longer smoking.
Various other transient runners for selling.
PostPosted: Fri May 04, 2018 7:37 pm
thanks for the comments :bluewave: just finishing the barrel,removed everything and seal it up with silicone sealer and left alone for 2days to dry properley,before that i shot blast few more parts,,,,brake servo front and back piece,need to make a retain collar for the pedal side bellow to sit on,now got the seal to seal up the black inner sliding plastic bit that i had trouble in removing
also blasted the tow bar i got(thank you) and sprayed it first in acid etch and left it to dry outside and then overnight indoors(keep it warm :lol: ) and bought some new bolts for it
cron
