It is currently Fri Apr 19, 2024 3:27 am
 Post subject: Waxstat Carburettors ?
PostPosted: Wed Mar 07, 2007 8:33 pm
Which Carburettors have these in them ? What do they do?
Mine are twin su HS4
Are these one and half in Su ?
 Post subject:
PostPosted: Wed Mar 07, 2007 8:54 pm
Yup, HS4 is a 1 and 4/8th inch carburettor, or 1 1/2 inch. An SE should have waxstats.
 Post subject:
PostPosted: Fri Mar 09, 2007 12:05 pm
TDC Staffs Area Organiser
The theory behind Waxstats is as the engine gets hotter it weakens the mixture, was a fashionable thing to do in the 70's to reduce emmissions. problem comes when the wax goo gets tired and when parked sometimes heat from the engine bay gets into the waxstats weakening the mixture making them difficult to start and/or run like a pig. Burlen fuel systems will sell you jets that look like waxstats but don't cotain the wax pellet or you can remove the waxstat pellet and replace with 1p pieces. This costs 4p with 2 carbs and works very well once adjusted .
In my opinion they belong in the bin along with butterflies with poppet valves in them, solder them up or replace with solid ones easily available.
 Post subject:
PostPosted: Sat Mar 10, 2007 6:39 pm
Thanks thats better I know what they do now!
Had an offer of a pair Su that a from a 1500 mg Mig might buy em to stick on.
Users browsing this forum: No registered users and 17 guests
