Check the points are on the peak of the cam after replacement.
Reconnect the wires, and replace both screws and back off about 1/8 turn so it is just possible to move them with a screwdriver in the adjustment slot.
Using one hand to check the points gap, use the other on the screrwdriver to open / close the gap.
Re-assemble in the reverse order.
There ! 52 minutes of a lunch-hour including cleaning up the old points with a fine file.
Anyone know why I'm restricted to 3 uploaded attachments ? I've seen postings with many pictures.
Cheers All,
