It is currently Sat Jun 23, 2018 8:25 am
Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2
 Post subject: Re: New Dolly
PostPosted: Tue Jun 16, 2015 7:20 pm
You can also use a Stag rear subframe mount at £15 - its taller than the proper mount but in a way that does not matter when its fitted. You will need a longer bolt too but at £20 total its your cheapest solution.
Link here:
http://www.ldparts.co.uk/shop/shop.php? ... uct&pid=68
I have it on my car and it works fine.
Matt.
Thanks Matt, will order one of those, have you got a link to right length bolt?
Cheers Rich
1981 Dolomite 1500 Auto
1971 Toledo 4 door
PostPosted: Thu Jun 18, 2015 7:54 pm
Today whilst using car , put her into reverse when coming out of parking space and it really thumped, had a quick look as it felt like something rubbing on gearbox tunnel. Got it on ramps when I got home and nothing untoward, so just put her into garage and thumped again as I put her into reverse!
Any ideas?
Cheers Rich
1971 Toledo 4 door
PostPosted: Thu Jun 18, 2015 8:29 pm
Was the idle speed ok or higher than normal? Higher would cause more of a thump
PostPosted: Thu Jun 18, 2015 9:06 pm
Hi Tony, Idle speed was fine and engine hot so no choke, just thumped in reverse, when putting in drive was fine and drove fine, but it was something that definitely hasn't happened since I bought car. Primed box and checked fluid and was fine.
Rich
1971 Toledo 4 door
PostPosted: Thu Jun 18, 2015 9:14 pm
Link here:
Matt.
Cheers Rich
Hi Rich
I used an Audi suspension bolt, part number PSAB10 from Pearl Products as I had one lying about, but im sure something else suitable could be found at any motor factor or hardware store. Just make sure its high tensile.
PostPosted: Fri Jun 19, 2015 9:13 am
Rich
I've read in various places a 'cushioned thump' is to be expected. How that's quite defined is anyone's guess. I suspect the solution is probably to install a louder stereo and stop worrying ;)
1978 Triumph Dolomite MX-5 Build (Project) viewtopic.php?f=19&t=29239
1959 Morris Oxford IV Traveller in Red/Cream (Daily)
PostPosted: Fri Jun 19, 2015 9:43 am
Steve[/quote]
Cheers Steve, have driven it this morning and didn't do it at all.The cushion was definitely missing last night though..
Cheers Rich
1971 Toledo 4 door
PostPosted: Sun Jun 21, 2015 12:25 pm
Can anyone please explain how to ensure engine is TDC before I adjust tappetts? Have a Haynes manual but doesn't make it 100% clear enough..well not for me anyway :D . And what is the correct feeler gauge to use?
Cheers Rich
1971 Toledo 4 door
PostPosted: Sun Jun 21, 2015 12:58 pm
TDC Committee
Rich
. You need to use the rule of 9, check, adjust no 1, whilst no 8 is fully open/ depressed, 2 with 7, etc etc until you get to check 8 with 1 open.
Believe the clearance is 10 thou of an inch, ie .o10, or .25 mm in new money.
BWJ
1966 Triumph 1300 Royal Blue - fixed, ready to blow up
1972 Triumph Dolomite Sienna / David Brown
1967 BSA B40wd green
2017 Jaguar XE Grey
PostPosted: Sun Jun 21, 2015 1:05 pm
Thanks Bruce, do you need to have engine on TDC or is it a case of rotating it manually each time to adjust clearances in order?
Rich
1971 Toledo 4 door
PostPosted: Sun Jun 21, 2015 3:34 pm
TDC Committee
Rotating each time Rich, let me know when you want to do it, and I'll nip over, and show you how
BWJ
2017 Jaguar XE Grey
PostPosted: Sun Jun 21, 2015 3:55 pm
Thanks Bruce will do :D
1971 Toledo 4 door
PostPosted: Tue Jun 30, 2015 6:39 am
TDC West Yorks Area Organiser
Now that you've established yourself on here, you should start posting in the "Dolomite related" section of the forum. That's where most of the forum traffic is and is the first place I go to.
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the modern)
"I can help you stop smoking in bed. Buy a water bed and fill it with petrol." - Bob Monkhouse OBE (1928-2003)
PostPosted: Wed Jul 01, 2015 9:57 pm
Ok thanks for that
1971 Toledo 4 door
cron
