guys having trouble balancing my sprints carbs,cleaned the pots,springs,needles etc,run it at 2500 to warm it up,as the haynes,played with the jet adjustment nuts on both,but the forward carb(nearest the bulkhead)still hisses much more than the other,just cant seem to get them to hiss at the same rate,ive done averything that the haynes says to the letter,very frustrating,also checked the usual,split pipes etc,plugs,dizzy points etc,all good
any suggestions...
ive searched for topics but cant seem to find any although ime sure its been covered before,
Have you made sure that the linkage is working properly? it's a terrible one for going out of whack and sloppy.
