It is currently Wed Apr 24, 2024 6:48 pm
PostPosted: Thu Nov 22, 2012 6:03 pm
EDIT: there is now a much simpler way of adding photos, see viewtopic.php?f=19&t=32626
Right hopefully this will work
Go to the top of the box when you post and click on Img
And it should look like this [ img ] * [ /img ]
Go in to your photobucket and in the top right hand corner of your pic you will see a cog, hover over it and a box will appear, one of the topics is share. Click on it.
You will then see 3 sub menu's along the top of the box 1) social networks, 2) Email, 3) Links. Click on Links. You then want to copy the direct link address.
You then paste the address between the image tags [ img ]http://i773.photobucket.com/albums/yy20 ... y/2013.jpg [/img ] (like this but without the spaces I have done at each end of the address).
When you do it right it will look like this
Hope this helps
Darren
Thanks Darren, that is a good explanation.
PostPosted: Sat Feb 08, 2014 7:07 pm
If you must attach photos to your post can you please resize them? I've found the ideal size to be 1024x768 pixels (It might be better just to change the horizontal size to 1024 pixels if the aspect ratio is different). The advantages are that the resized photos are a smaller file size (about 300KB) and you don't lose picture quality. You can easily resize photos with the Windows paint program and Microsoft offered a free program which resized photos.
PostPosted: Sat Feb 08, 2014 8:08 pm
I use 'Imageshack', you upload your pic, choose the size ( I use 800x600) and copy/ past the 'forum link' straight onto your post.
Can't get much simpler than that.
PostPosted: Sat Aug 09, 2014 11:19 am
I made this guide before for another forum but thought it would be helpful posted here.
Here's a quick guide for you I've mocked together. Others can use it in the future if they wish!
First of all head over to photobucket and log in. (On the basis of having an account - If you don't create one by going to "sign up")
After logging in press the "Upload" button on the top of the page.
Next up press the "choose photos and videos button".
From here a pop up will open where you can locate to the particular photo you want to upload. In this example I will use an old picture of my spit. To select multiple images just hold down the "ctrl" key on your keyboard and individually clicking each image you wish to upload.
When done press "open" and then it will start uploading the images.
This will display when all images have been successfully uploaded.
Press the view uploads button to go into your "bucket" on photobucket. (This image shows the picture I just uploaded.)
Select the image you want to put onto the forum and then on the right hand side of the screen you will see some links. You want to press the IMG one as displayed.
It will say "copied" when you press inside the box. This means that the link for that photo has been copied and is ready to paste onto the forum.
Then go onto the forum and into the reply section as you normally would. Click in the reply box and right click then "paste". Or hold down the "Ctrl" key and then press the "V" key.
When you post your reply the image will automatically display. However when just in normal reply mode you wont see the image displayed, just the code.
Louis.
PostPosted: Sun Feb 07, 2016 8:19 pm
I posted this as a separate thread I thought it would be useful in here as well.
Anyone who has been following my thread has probably seen the photos that I take.
One example being this, a load sensing valve for a Sprint:
I am a photographer (apparently not amateur any more because I know what I'm doing now!! :lol: ) and felt that taking time to produce good quality photos made me think more about the part that I am refurbishing and also provided a good reference for other people in the future if they wanted to know how something is broken down.
All of my photos are stored on Flickr and are copyrighted to me in the MetaData and because they are public photos I have also started watermarking them, I'll be going through the old ones and doing the same, this is something I should be doing as best practice because they are public and is by no means a result of anything going on here.
I know some of you guys have been using them to answer questions, that's great and it is one of the reasons I make sure these photos are publicly viewable and searchable so I thought I'd say this to make sure that everyone's happy and clear if they want to use one!
Registered forum users have permission to use my photos on this forum (http://forum.triumphdolomite.co.uk/) either by linking from Flickr or by copying from my restoration thread.
All I ask is that you quote me as taking the photo if it's not watermarked.
If you want to use one elsewhere just drop me a PM. :)
To access them you can either look at my restoration thread here:
viewtopic.php?f=19&t=27969
Or you can access the Flickr album here:
https://www.flickr.com/gp/91407512@N00/810dQX
Or you can just click on one of the photos.
When I have finished my restoration I plan to copy all of these images to a disc and send them over to the club.
Thanks all!
James
PostPosted: Thu May 18, 2017 9:09 pm
Just a random photo and nothing to do with Dolomites or 1300s, but I just wanted to try the new "add image" button. :D
Looks like there is only the one size?
PostPosted: Thu May 18, 2017 10:04 pm
No you an have any size you like, the first box you see gives you a flip down choice. The thumbnail always comes out small but if you click on it, it will come up the size you have set. Just been playing with it myself!
PostPosted: Thu May 18, 2017 10:47 pm
Thanks Steve, and Galileo, makes perfect sense. Thumbnail for the forum, click on the image and it takes you to the hosting site with a photo as big as you'd like to show. Perfect. :D
PostPosted: Thu Oct 19, 2017 6:14 am
Use the "Add image to post facility", it's in blue text beneath your text composition box when creating a new post.
For the old way, use Flickr or some such, just be aware that those 'free' sites have to create revenue somehow, and they tend not to be free forever.
PostPosted: Thu Oct 19, 2017 8:13 am
I did a post to help show this (a sticky in the resto section).
Users browsing this forum: Amazon [Bot], Google, Trendiction and 46 guests
