It is currently Sat Apr 27, 2024 4:16 pm
Post new topic  Reply to topic  [ 226 posts ]  Go to page Previous 111 12 13 14 15 16 Next
PostPosted: Wed Jan 02, 2013 3:39 pm
Not as of yet, I have a pretty good idea of what I need to do with it though, its just a matter of trying to package it all in so everything else fits. Once I have finished off with the last of the metal work I will drop the dummy block back in and start sorting that side of it and all of the pipe and wire routing.
PostPosted: Thu Apr 11, 2013 10:25 pm
Finally sorted the last of the cage and Brian finished off the welding.
More parts have been purchased.
Oil stat & catch tank.
Most of the electrical parts needed, wire, relays etc starter motor and oil cooler & FPR.
Ecu has also been ordered and should be here early next week.
Dropped the dummy engine back in So I can mock fit all the hoses to work out positioning of all the ancillarys.
Knocked up a mock up expansion tank, the proper one will be in ally.
I have had to send the oil pump back to pace as I ordered a long nose when on fitting a short nose would have fitted better.
PostPosted: Fri Apr 12, 2013 6:05 am
:shock: :shock: :shock: :thumbsup:
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
PostPosted: Fri Apr 12, 2013 11:44 pm
:thumbsup:
Thats a pile of wireing !
PostPosted: Sat Apr 13, 2013 5:03 pm
Shocking....
lee good. 8)
PostPosted: Sun Jul 14, 2013 9:26 am
Have moved on to some the more time consuming jobs now.
Brackets made for mounting the ECU, water pump control module and fuse box.
Wiring loom from the bulkhead sockets made up and fed into the car.
5 Seperate looms going into the engine bay from bulkhead sockets.
The large bunch of wires is solely for the engine.
Started running the wires to all the places they need to go and fuse box half wired up.
Fuses, Relays & ECU pretty much all wired up at the control end, just need to sort out the earth termination points. moving onto sorting out the stalks today if I don't melt.
Dry sump hoses running from the front to rear bulkhead, I had to stop the the dry sump system whilst I waited for the pump to be modified to a short nose which to nearly 4 months for some reason.
PostPosted: Sun Jul 14, 2013 10:32 am
Electrickery ,
I hate it
Big hurdle nearly sorted,
It was 50deg in my workshop so I know what you mean
I'm not bothering unt this dam weather clears off LOL
PostPosted: Sun Jul 14, 2013 11:38 am
That's dedication for ya.You could be out supping beer and eating burgers. :lol:
Its great to read about projects that people do that have great skill sets.
Im gobsmacked when I look at pics and can then appreciate the time/work/money spent doing these things.
Well done fella. =D>
P.s
Well done to all the others also who dedicate themselves to their projects :thumbsup:
PostPosted: Sun Jul 14, 2013 9:28 pm
I'm not a fan of them either daz, but you can only put these things off so long.
cheers maximus, fear not I found time to fit in a BBQ and some beer. Lol
 Post subject: Hi Neil........
PostPosted: Mon Jul 15, 2013 3:46 pm
:? I am not sure about this arrangement of hoses?
The RH top hose on a Sprint (or 1850) is for the vent from the radiator.
I am thinking it will be better to fit a hose tail into the water transfer (at the back of the cylinder head) and use this to connect the heater input hose.
Also, I am thinking the expansion tank is a little low (relative to the engine). For filling/topping up you can undo the tank and hold it higher (if there is sufficient
give in the hoses), which is what I think you'll have to do because your strut brace limits the options for tank location.
With its takeoff from such a high relative position, will the flow of coolant to the heater be maintained at all times?
If I am talking rubbish please do tell me :D ,
I am finding this build fascinating and awe inspiring.
 Post subject: Re: Hi Neil........
PostPosted: Mon Jul 15, 2013 6:01 pm
You're not :)
However, it's worth considering how the water actually flows through a slant and where the heater is relative to everything else. The standard setup has the heater parallel to the radiator, that's where it is here it just looks a little different because the water pump has moved and the radiator is completely different. I forget exactly how the radiator hoses go.
I think the heater will be just fine as long as you can get all the air out when you fill it (hence the bleed valve in the heater hose). The tank is higher than it looks I think :)
PostPosted: Mon Jul 15, 2013 7:51 pm
and, you fill it through the plug on the top of the thermostat housing. :)
PostPosted: Mon Jul 15, 2013 10:41 pm
I would re route the heater hoses under the inlet manifold
I would also run a very small bleed of the heater hose back to the expansion tank so it was continusly self bleeding ,
I used a plastic restrictor in the hose with a pilot hole drilled in it
Instead of the bleed screw,
PostPosted: Thu Jul 18, 2013 10:15 pm
I don't think I will have any issues with the take off I have used for the heater. As for the rad hoses yeah they are in a far from ideal position but due to the room I have on the inner bulkhead and the way the heater is fitted there is not a good solution. I will have another look and see if I can improve it.
Cheers for the comments all are welcome.
PostPosted: Thu Jul 18, 2013 10:43 pm
I Have moved the starter motor to the right side of the engine.
Cant say as I am massively impressed with the starter, I had both it and a lucas one on set up on the bench at the same time and the worn lucas one was both faster and more positive in engagement and disengagement. Happy with the alignment though.
All the fittings for the dry sump hoses.
Dry sump pump fitted on a temporary bracket and engine mount modified to clear, fortunately I had only held them together with 4 tacks.
Column stalks wired up.
More electrical parts turned up.
