It is currently Tue Apr 16, 2024 7:21 am
PostPosted: Sat Sep 10, 2011 2:14 pm
Sealed Beam 5 inch twin-filament headlights have suddenly become NLA .
Quartz Halogen with an H4 bulb is a semi-drop-in aftermarket replacement, but will need relay switching.
BR.
PostPosted: Fri Sep 23, 2011 8:38 pm
- Engine bay bulkhead pad.
Do you mean the sound/ heat insulation?
PostPosted: Fri Sep 23, 2011 9:02 pm
Yup
PostPosted: Fri Sep 23, 2011 9:10 pm
Yup
That is going to be ripped out sometime this week, as i'm soundproofing my car. Glad i read this now :-)... i will go gently. What good is it, if it's shot to pieces though? :?
PostPosted: Fri Sep 23, 2011 11:06 pm
Still useful as a pattern for other people to make copies, same is true of the black yoga mat from under the back seat cushion....
PostPosted: Sat Sep 24, 2011 7:45 am
ok, i will keep hold of it
about the rear seat mat :cry:
PostPosted: Mon Dec 12, 2011 9:05 pm
I've been informed by Fitchetts that Sprint wheel studs (7/16 unf) are NLA any comments? Steve
PostPosted: Mon Aug 27, 2012 12:08 pm
spark flash guard for sprint dissie ?
(the plastic round shield that fits over the points)
rimmers have them as NLA.
are they getting rare ?
PostPosted: Mon Dec 10, 2012 12:54 pm
Centre caps on Sprint alloy wheels seem to be made from the most delicate metal known to man so is there any chance of those being re-manufactured out of something just a little more resilient...?!
PostPosted: Mon Jun 16, 2014 4:10 pm
Door lock buttons (if that is what they are called) need to be hoarded as they can become brittle and crack/snap if handled roughly...!!!
PostPosted: Thu Jul 10, 2014 8:15 pm
http://www.chriswitor.com/proddetail.php?prod=615888 :)
PostPosted: Wed Nov 25, 2015 3:36 pm
- Original inlet hose supports
- clutch master
- clutch slave
- starter motor including solenoid
- alternator
Tinweevil
I'm 70% sure I have the hose mounts on my car and I definitely don't need them
Engine swapping it so I'll be using the clutch from the doner car
Engines for sale so I have starter motor to spare
PostPosted: Sat Apr 09, 2016 9:07 am
according to Autosparks the multi-pin connector plug for the fascia warning cluster on the dash wiring loom is also NLA.
 Post subject: Re:
PostPosted: Thu Dec 29, 2016 7:36 pm
I've bought drum retaining screws recently from my local factor, I'll check they are still available next time I'm there and get a stock if they are on the way out.
Tinweevil
The drum retaining screws would they be the size as used on a stag,if they are any of the stg suppliers sell them
 Post subject: Re: Re:
PostPosted: Thu Dec 29, 2016 8:39 pm
Tinweevil
Drum retension screw is fitted across the range of Triumph's - TR2/3, stag, herald, GT6, spitfire,2000 / 2500 and of coarse Dolly - part No. V5435 qty of 4 required.
RBros & JPaddocks have them in stock if anybody whats any.
Paul
Users browsing this forum: Google, sm519193 and 20 guests
