It is currently Wed Apr 24, 2024 1:44 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
 Post subject: New Dolly
PostPosted: Fri Apr 17, 2015 5:52 am
Well took the plunge and now have a Dolly :D , She's a 1500 Auto. Drove her back 93 miles last night and she didn't miss a beat. Only concern / problem was a clunk when coming to rest at lights or junction from mid to rear of car? Didn't move on temp guage, no other noises apart from many horns flashing high beams, which worried me at first but it was just people appreciating her I hope!!
Just needs a good wash and valet which hopefully will be done after work today so may get some pictures up later. Any ideas on said clunking most welcome. Also put fuel additive in when filled her up, she is an 81, so will she deffinately need that?
Rich..
1981 Dolomite 1500 Auto
 Post subject: Re: New Dolly
PostPosted: Fri Apr 17, 2015 9:14 am
My auto used to do that. It's the slack in the diff/prop being taken up before the gearbox drops out, you don't get this on a manual as you have the clutch down before you get to that point. Mine did it for years without breaking anything..
Age is irrelevent, if the head hasn't had an unleaded conversion by a previous owner then yes, you should. Some people run without and then when it starts causing problems they get it converted - I'm more a fan of prevention than repair though!
PostPosted: Fri Apr 17, 2015 4:45 pm
Thanks for that Steve, was a bit worried about it!Going to check diff oil aswell tomorrow. Anyone shed any light as to what type of oil for engine and for diff please?
Rich
PostPosted: Fri Apr 17, 2015 5:06 pm
Rich
For engine oil use 20w50 mineral (Valvoline VR1 is good). The diff is EP80/90 GL4 (NOT GL5). Auto box is Comma AQF - almost all other ATF is wrong and will do damage.
PostPosted: Sun Apr 19, 2015 2:16 pm
Steve, this gearbox / diff noise / clunk is intermittent, have done over 200 miles since I picked her up on Thursday and it has happened around 75% of that time when coming to a stop only! Driving she is perfect and goes through the gears nicely and kickdown is very good aswell, not ever having had a classic car before and never an automatic new or old, am I just being paranoid? Diff oil was fine and transmission fliud too but wasn't as red as it maybe should be, would it be wise to drop fluid and install correct AQF for peace of mind? thanks Rich..
PostPosted: Sun Apr 19, 2015 7:55 pm
Good user name....
My sprint reg is RJF 70R!!!!
1976 Taihiti Sprint
2020 Jaguar iPace ev400
2021 Toyota Yaris GR-Four
2011 Super Skoda Fabia 1.2 S HTP
PostPosted: Sun Apr 19, 2015 9:35 pm
Was intermittent on mine too, it'd predictably do it at some junctions on my regular routes. I tried investigating and the gearbox/diff idea was the only thing that seemed plausible - everything else was perfect. I replaced all the rear suspension and bushings (was doing that anyway) and it still happened. Granted I can only speak for my car, maybe a few other people can chime in?
As for the fluid, given how much of a pig the auto-boxes are to work on it may be worth new fluid anyway. It's not uncommon for people to just put in whatever ATF they can find, but there are many guides online saying how important it is to use Comma AQF.
Sadly I'm not really able to do more diagnosing on mine as the engine/box is being changed for an MX-5 1.8 litre engine... Big project!
PostPosted: Sun Apr 19, 2015 9:38 pm
Good user name....
Great REG you have there :D
PostPosted: Sun Apr 19, 2015 10:15 pm
As long as you use the correct spec transmission fluid (Ford M2C-33G) it will be fine. This is what I used on my last fluid change.
Whatever you do, DON'T use Dexron fluid.
PostPosted: Tue May 12, 2015 8:47 pm
Think I have found the cause of the clunk / thump when coming to a stop most of the time in my dolly! The transmission mount is shot on the gearbox subframe. Its auto have only found 1 replacement and it's 80 quid on ebay :shock: anyone else have a spare auto subframe or just the bush?
Cheers Rich
PostPosted: Tue May 12, 2015 9:11 pm
May be able to help with that.. I'll try and get to my unit tomorrow and check/take pics :)
PostPosted: Wed May 13, 2015 5:51 am
Thanks Steve..
PostPosted: Wed May 13, 2015 10:53 pm
The high price is due to the limited availability. The part number is 155300 if that helps. I'm sure somebody on here said that the Stag one would fit.
PostPosted: Mon Jun 15, 2015 1:01 pm
Chris Witor has these in stock for £55 plus the dreaded VAT and his excellent next-day delivery.
PostPosted: Mon Jun 15, 2015 2:24 pm
You can also use a Stag rear subframe mount at £15 - its taller than the proper mount but in a way that does not matter when its fitted. You will need a longer bolt too but at £20 total its your cheapest solution.
Link here:
http://www.ldparts.co.uk/shop/shop.php? ... uct&pid=68
I have it on my car and it works fine.
Matt.
Users browsing this forum: No registered users and 15 guests
