It is currently Sun Apr 28, 2024 9:41 am
Post new topic  Reply to topic  [ 105 posts ]  Go to page Previous 1 2 3 4 57 Next
PostPosted: Thu Jan 28, 2016 10:16 pm
OUCH!
Not a wound you want to bash again or get grease in!
PostPosted: Sun Feb 21, 2016 12:18 pm
My hand has finally healed enough to use, so started to get the engine ready to take out.
It was all going well until I got to the bottom bolt on the exhaust to manifold joint. Whoever designed that should be shot!!
So after getting soaked and nearly blown away finally called it a day. I did some research online and removing the engine and sub frame from below now looks like a better option.
Any advice would be appreciated, at least I can do all the bushes whilst it's all out and refurb and painting of all the suspension.
PostPosted: Sun Feb 21, 2016 9:00 pm
Just lift the engine out with the downpipe in situ. It will be easier to remove with the engine out of the car. If you're going to renew the subframe bushes get the Super Flex ones. I fitted them last year when I had to have a couple of my subframe mounts repaired. While the subframe is off you can check the condition of the chassis legs. The Club do these for £80 per side. I had an offside one fitted in 2014.
PostPosted: Fri Apr 01, 2016 8:55 pm
Thanks for the advice, got the bushes you recommended.
All the sub frame, engine etc all out and in bits now. Now got to clean it all before painting. I might get the sub frame blasted and might even get it powder coated to.
Over the last few weeks I have got loses of little jobs done so quite happy. I'll put some photo on soon .
John
PostPosted: Fri Apr 01, 2016 9:00 pm
File comment: All parts back to bare metal and the etch primed and finished in satin black
PostPosted: Fri Apr 01, 2016 9:13 pm
File comment: Before pic
File comment: After pic
File comment: Finished rocker cover
File comment: Shock all ready
PostPosted: Fri Apr 01, 2016 9:20 pm
Looking shiny, looking tasty.
PostPosted: Fri Apr 01, 2016 9:30 pm
Once I got the engine and gear box apart I found a lot of oil all inside the bell housing, I take it that it shouldn't be like that and a seal has gone?
I'm good at body work but still learning the mechanics as I go, so when I get to rebuilding the engine it will be a learning curve. Changed engines before but never pulled them apart before.
Will post some photo of more interesting bits when I get to them
John
PostPosted: Sat Apr 02, 2016 11:56 am
It sounds like your crankshaft rear oil seal has gone. You can either replace just the seal or do what I did which was to remove the housing for the seal. If you remove the housing, you will need a new gasket and don't forget to remove the 2 bolts where it is bolted to the sump. It would be a good idea to change the clutch while you have the engine out of the car.
PostPosted: Sat Apr 02, 2016 12:40 pm
Thanks, I'm going to completely strip the engine down, I've got a new short engine to build, new pistons, gaskets, bearings all sorts !
I found a couple of broken brackets on the upper wishbones that I'll have to get made as can't seem to find them anywhere but there easy to do so shouldn't be a problem. Still cleanup all the suspension bits seems to take forever but will look good once it's all done.
Have a good weekend everyone!
John
PostPosted: Sat Apr 02, 2016 2:35 pm
John
Let me know what brackets you need, I have several subframe/suspension sets here.
PostPosted: Sat Apr 02, 2016 4:17 pm
John
I have a few bits too.
1997 TVR Chimaera 450
PostPosted: Sat Apr 02, 2016 4:39 pm
Thanks guys
I'll take some photos and put them on later
John
PostPosted: Sun Apr 03, 2016 1:09 am
Yum those ally bits are really clean and shiney.
How did you do that?
PostPosted: Sun Apr 03, 2016 12:43 pm
Looks like silver spray paint, as some of the masking hasn't been removed yet.
Users browsing this forum: Bing and 2 guests
