It is currently Fri Apr 19, 2024 2:21 pm
Post new topic  Reply to topic  [ 300 posts ]  Go to page Previous 19 10 11 12 1320 Next
PostPosted: Sun Nov 20, 2016 11:41 am
my gauges went hay-wire the other day,so had a look at stabilizer mounted on bulk head,found it was not earthing properley,cleaned earthing areas both bulkhead and stabilizer housing,everything working as i should.....must buy elecy stabilizer for next year or when its goes
29 pence each:
http://www.maplin.co.uk/p/ts7810cz-1a-p ... case-n38ca
Works a treat, buy several in case you blow one! :D
how do you wire them up?
PostPosted: Sun Nov 20, 2016 4:58 pm
29 pence each:
Really easy, the link above has a tab for Downloads, click on that you get a datasheet, the datasheet shows it's a TO-220 package, and gives the pin numbers - IMPORTANT - do not get the the pin numbers the wrong way round, if you put power on the wrong way round the package can go bang and lots of little bits fly in every direction. Allegedly. :oops:
Bolt the chip to the bulkhead, metal to metal (I used a little heat sink paste) the middle pin is earth, solder a wire to this pin and bolt the wire to the bulkhead, remove any paint around the connection point. The middle pin is also connected to the metal rear of the chip, so you could not bother connecting it, but belt and braces.
Pin 1, solder a cable to this (use heatshrink tubing to cover up the bare leg after soldering) and I used the input connection of the now defunct original voltage regulator as the feed.
Pin 3 solder a cable to this and it goes to the now defunct output cable from the original voltage regulator.
I've tucked mine under the original voltage regulator, used the original wires and connectors, so it's unseen and can be swapped back in seconds if anyone feels the need for the true original set-up.
PostPosted: Sun Jan 22, 2017 11:14 am
sorry for long delay in saying thanks for the link.
i did find the problem-alternator was dis-charging when it was at 2700-3000rpm,so new alternator fitted 65amp all electric problems have gone 8) gauges reading properly,engine starts easier,headlight dont dim anymore,stereo is thumping
PostPosted: Wed Feb 08, 2017 9:17 pm
the couriers have brought me a set of hs4 twin carbs,manifold,air filter metal type,complete setup-ready to fit----huge thanks to Dazasdolly :D nice one,will fit when weather is better and not freezing cold.that should make 1300 dolly go better then single carb setup
if 1300 single carb produces 59bhp`ish,what would twin hs4 make? any ideas
PostPosted: Wed Feb 08, 2017 11:50 pm
I'll take a stab at an extra 7 bhp IF the carbs are set up right. The 1300 TC had an extra 14 bhp over the SC, but I think it had a different cam......
PostPosted: Thu Feb 09, 2017 12:09 am
thanks for that,better then i thought,my brain thought 4-5bhp tops,,,7bhp`ish sounds good,if the tc version has 14bhp extra what cam should i look out for?
colortune,carb balancer and strobe light at the ready,but later on rolling road test just around the corner from me
 Post subject: Aye...
PostPosted: Thu Feb 09, 2017 10:19 am
and a decent exhaust manifold, just like what the TDC has commissioned :D .
If you want a good improvement of economy and performance then go EFI.
More 4's Car SOS did this on a Herald 13/60 using an Emerald ECU.
PostPosted: Thu Feb 09, 2017 10:34 am
its a £grand plus for efi setup and what the price on commissioned manifold?
 Post subject: Okay.......
PostPosted: Thu Feb 09, 2017 1:57 pm
There are several ways to do this,
one option is http://www.webcon.co.uk/shopdisplayprod ... at=Triumph,
bit others go bespoke and make their own.
if you wish to learn more, there is a wealth on the Sideways Technologies forum
http://sideways-technologies.co.uk/foru ... app=forums
including a beginners guide from Nick Jones.
PostPosted: Sat Feb 11, 2017 10:30 pm
PostPosted: Sun Feb 12, 2017 1:57 pm
These are available to TDC members.
PostPosted: Fri Feb 24, 2017 10:40 pm
just refurb the malpassi king filter,cleaned up with dremal brushes and laquer`d it,next to do is mounting bracket and spray it russet brown so it blends in with the engine bay body work
PostPosted: Mon Apr 24, 2017 11:56 am
looking to replace the brake hoses on my dolly1300 and came across these for sprint,are they the same as normal 1300 dolly
http://www.ebay.co.uk/itm/Euroquip-Blac ... 1838422614
anyone thoughts?
 Post subject: Okay…….
PostPosted: Mon Apr 24, 2017 1:28 pm
The fronts are the same but the Sprint uses a different back hose to the other Dolomites
so that set won't do.
PostPosted: Mon Apr 24, 2017 1:37 pm
ok,thanks for that info,,forgot about the sprint axle is different :(
so it looks like angtriumph one it is then
Users browsing this forum: No registered users and 68 guests
