It is currently Wed Dec 12, 2018 12:35 pm
Post new topic  Reply to topic  [ 173 posts ]  Go to page Previous 18 9 10 11 12
PostPosted: Mon Jul 31, 2017 8:26 pm
Lunchtime today, got the engine settled on 3 infinitely adjustable caravan axle stands, centred up on the centreline of the car and adjusted for slant (the engine is canted 7 degrees to the nearside, so it's still a slant!)
At this point I realized that i've completely forgotten to acquire the Volvo 240 engine mounts I need (the Vauxhall originals are too bulky to fit the car) so after a quick visit to the bay of E I have a pair coming for £15. In the meantime, it's back to the salt mines (AKA wiring) as I need the mounts in place on the engine to do the CAD for fabbing the subframe mounted engine support brackets!
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Fri Aug 04, 2017 6:36 am
TDC West Yorks Area Organiser
Fixed all the PB links so they will work.
Meetings take place on the 1st Wednesday of every month at The Hollies Sports & Social Club, 12 Hough Lane, Bramley, Leeds, LS13 3NE
1972 Dolomite 1850 auto (NYE 751L - The rolling restoration)
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the modern)
1995 BMW 318i (M265 PNC - Project Bimmer)
2004 Vauxhall Corsa Design 16V (FE04 FKG - not mine! Being revived)
"There is only one way to avoid criticsm: do nothing, say nothing and be nothing." Aristotle
PostPosted: Fri Aug 04, 2017 8:00 am
Thanks Dave!
PostPosted: Tue Aug 08, 2017 9:28 pm
The engine mounts I ordered came on time - and are, of course, NOt the ones I ordered! seems I was taken in by a "file picture" The company have kindly refunded my money AND not insisted I return the offending mounts, but were unable to supply correct ones without a reg number for the (non existent) Volvo I wanted them for! Nothings ever easy in the modding game!
Having been temporarily foiled here, I've been raiding the Stag parts bin again, this time for a centre console. I'm not a big fan of the Dolomite parcel tray and wanted something more substantial than the coin tray. This seems to fit the bill (and the car) and with a bit of hacking about will take the stereo, trip computer screen, electric window switches and a few other small bits.
A chippy mate will be making the 3 bespoke wood panels I will need and hopefully getting a decent match on veneer and colour with the rest of the (all matching pieces) dash!
I am also investigating the possibility of using Stag mechanisms to remotely operate the front !/4 lights. I mentioned the idea to Mahesh and he has helped me with pics that look promising. And also adopted the idea for his car, except that he now plans to go one better and run his 1/4 lights on electrickery!
PostPosted: Tue Aug 08, 2017 11:17 pm
This is my home made one 15 years ago.
The fresh air vents are replaced by tweeters that do fit without any modification. I only glued some vent knobs on them to mak you like twice.
PostPosted: Wed Aug 09, 2017 3:14 pm
You should see a nice 24oGLT add on ebay that you can nick the reg number from if that's the one you want...
PostPosted: Thu Aug 10, 2017 7:44 am
If I think really hard, I can probably remember the reg of the Volvo the Carledo ones came from! In fact I can, it was A858 XTN, but that car was scrapped maybe 15-18 years ago and is probably not on anybodies database anymore! There are 2 different sorts of mounts fitted to 240s and there doesn't SEEM to be any logic in the application. Some companies also list different mounts for left and right side! It's a bit of a minefield!
PostPosted: Mon Apr 23, 2018 1:39 am
A little update, the engine mount problem is solved, turns out that what I needed were 2 RHS mounts when what I originally ordered were 2 LHS (or vice versa) but aligning the engine and trans in the car has thrown up another much more serious problem, in that the rear of the gearbox has been forced way too low by the large diameter Vauxhall "Rotoflex" type front prop joint interfering with the tunnel stiffener just aft of the removable tunnel section.
After a lot of skull sweat and theorizing I came upon a possibly practical solution and bought (ebay, where else) a Sprint gearbox output shaft flange, removed the huge tripod flange from the trans and took them both to my tame propshaft man at Proptech in Hartlebury for an opinion. I am now convinced that he is that legendary guy that can do anything with nothing as he has just given me back THIS:-
He's cut the tripod off, turned a step into the shaft and cut and bored out the flange of the Sprint part to an interference fit on the Vaux output section then shrunk it on and welded it in place. Fitting this has enabled me to lift the rear end of the trans by nearly 1.5" and line everthing up nicely WITHOUT modding the tunnel in any way (NO BIVA FOR ME!) Next weekend should see me fabbing the engine and gearbox mounts, then I can measure for the propshaft and get him started on that. He moans at me all the time about these bespoke jobs, but he always comes up with the goods! I think that, secretly, he likes the challenges! Hopefully, it will be strong enough to withstand the rotation twist of hard driving, but on the upside, being an automatic, the shock loads will be much lower than on a manual. He says he's done this sort of thing before and it's worked, so i'm cautiously optimistic, time will tell!
In other news, the engine/trans management loom is finally nearing completion (as is my planning permission for "temporary" use of the kitchen table) there is still a 3rd loom to build for electric windows and central locking that will be a scratch built job but that can wait if need be and be added later, the feeds and relays have already been integrated into the main loom.
Since I want to do all my hole drilling, bracket making and welding around the bulkhead and engine bay BEFORE it gets painted, which requres that I actually fit most of the stuff that is needed to wire and plumb the motor, I am sorely tempted to try and get it running before I pull it all out again to get the engine bay/doorshuts/inside of doors/inside of boot etc painted. This will give me a much needed mojo boost and mean that when it all goes back after paint, I KNOW it will run!
Users browsing this forum: shaunroche and 1 guest
