It is currently Sun Aug 19, 2018 3:31 am
Post new topic  Reply to topic  [ 653 posts ]  Go to page Previous 130 31 32 33 3444 Next
PostPosted: Fri Aug 11, 2017 6:36 pm
I was going to suggest you weld a triangular fillet into the corner of your mounting plate, just to make it a bit more rigid, but you probably wouldn't welcome the idea now that you've painted it! :roll:
Also, you could use or adapt the mountings of the mounting plate for your earths to keep the wires shorter and tidier (or even hide an earth point behind the mounting plate, although that would mean you'd have to remove the plate if you ever need to access the earths in future).
PostPosted: Fri Aug 11, 2017 6:48 pm
TDC Spares Officer
Anything's possible, it's developmental. I consider this as a first prototype! :D
PostPosted: Fri Aug 11, 2017 6:58 pm
TDC Spares Officer
It's actually pretty rigid, but I feel that it could be improved, I don't like the mounting tabs and the hole that the wires pass through to the fuse boxes could be a tad wider. I think a triangular fillet would help rigidity, I'll wait until the Hotstart is mounted. In the meantime, well for the winter, I think it will be fine. You could easily have something like this laser cut.
Relays are mounted using number plate tape! Everything just needs to be re-taped and mounted. The headlights need the new connectors fitted and we should be done here.
PostPosted: Sun Aug 13, 2017 4:32 pm
I guess its the photo and being a wag I couldnt help but point out you dont want the relays knocked out when you shut the bonnet....:-)
Good job...apart from using PURPLE wiring for the coil!. Purple is only for non ignition fed circuits...as any fule knoe...
PostPosted: Sun Aug 13, 2017 7:29 pm
TDC Spares Officer
Don't worry that's why the bonnet stay'a there! So I can make sure it doesn't hit anything.
You can write to lumenition about the purple wire!
PostPosted: Tue Aug 15, 2017 12:10 pm
Nice job, and great to see your article in Classics Monthly. I will have to try to get a copy, but it is very difficult to come across around here.
Image Thanks Photobucket :(
PostPosted: Tue Aug 15, 2017 10:37 pm
One comment. I wouldn't put the ceramic heating element on your lumenition module.
Jeroen.
PostPosted: Wed Aug 16, 2017 7:55 am
Wow! That takes me back! I wonder how many others on here recognised the quote and it's source?
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Wed Aug 16, 2017 8:12 am
TDC Spares Officer
Jeroen.
I'll turn it around so it doesn't sit on top of the module, it sort of hangs mid air!
PostPosted: Wed Aug 16, 2017 8:15 am
TDC Spares Officer
I thought it was a Deep Purple reference!
PostPosted: Wed Aug 16, 2017 11:35 am
:wink:
Trevor
2008 X-type 2.0D SE
PostPosted: Wed Aug 16, 2017 6:41 pm
Not quite! Its from "The secret diary of Adrian Mole (aged 13 and three quarters)" a book I first read at the age of 12 ( the year we won the world cup) As you can tell from the speeling, child illiteracy was already gaining a hold in the 60s!
PostPosted: Thu Aug 17, 2017 12:15 am
That would have been "Any Fule Kno That".
PostPosted: Thu Aug 17, 2017 8:01 am
It is indeed Adrian Mole, but I thought it was from "down with skool" or somesuch. I think DP being contemporaries of us aging baby boomers
would have used a common source...
But we digress....cracking work as usual James...who is of course a tad our junior....
PostPosted: Fri Aug 18, 2017 2:50 pm
Remembering Jonners background, I suspect he was quoting from even further back in history and location.
Like 1909 ? Not that I'd wish to imply that sort of age for him :)
I have a book from 1909 entitled " Yarns Ancient & Modern : by W.H. MacDonald basically a collection of my Grandfather's era of short stories.
One of these finishes with the words ...
"Awa ye bacon-faced fule; Keep yer daft heid inside "
I dare say Iain could quote even more uses of the words.
cron
