It is currently Thu Apr 18, 2024 6:24 pm
Post new topic  Reply to topic  [ 222 posts ]  Go to page Previous 111 12 13 14 15
PostPosted: Mon Feb 26, 2018 1:46 pm
Always keep looking for the good things in bad situations. As it's the same side you don't have to type allover again. Just copy and paste some old posts about the replacement.
PostPosted: Thu Mar 01, 2018 12:43 pm
The motor factor wouldn't exchange the driveshaft but they've provided me with a new CV boot and the proper clips. I've farmed out the job to the local garage because I don't particularly relish the prospect of replacing an outer CV boot in sub-zero temperatures in ankle deep snow. I just hope that I don't have to have the outer CV joint replaced as well...
PostPosted: Fri Mar 02, 2018 7:59 am
The extreme weather meant that it didn't get done yesterday so I'm without transport for another day. I've decided to get the CV joint replaced as well for peace of mind.
PostPosted: Fri Mar 02, 2018 9:44 am
If you are getting the joint from the same motor factor..... I would not bother :(
PostPosted: Fri Mar 02, 2018 12:35 pm
No danger of that. The garage will be sourcing it elsewhere. It wasn't the CV joint that was the problem. It was the failure of the boot that let the grease out and the nasties in.
PostPosted: Fri Mar 02, 2018 6:11 pm
But what about the boot? As I mentioned elsewhere, if you use the one given to you it WILL fail. Spend a tenner on a genuine OEM or similar boot.
No idea at all why the factors won't change it. They ought to. Obviously they have zero customer care.
PostPosted: Sat Mar 03, 2018 9:05 am
The new CV joint should come with a new boot. If it doesn't, use a Duraboot stretchy boot but fit it without stretching it - i.e. knock the old joint off the shaft, slide boot onto shaft, use half the supplied grease to fill the void of the new joint, half to the inside of the boot, knock the new CV joint onto the shaft, position the boot and fit the supplied clips. I have replaced hundreds of CV boots with Duraboots in this way, they last forever if fitted like this because they are designed to stretch over the joint but if you fit them without stretching they last indefinitely.
PostPosted: Sat Mar 03, 2018 12:08 pm
The garage ended up fitting a new CV boot instead of the one I supplied because it wouldn't fit properly. The CV joint was fine so it didn't need to be replaced. I'm hoping that's the end of this little saga.
PostPosted: Sat Mar 03, 2018 12:27 pm
Sounds like an honest garage :D Obviously not "qwik s**t" :(
Glad it's sorted.
Cheers,
PostPosted: Sat Mar 03, 2018 12:41 pm
I'd be driveshafting it right up their arses if any of my suppliers did this to me
PostPosted: Sat Mar 03, 2018 1:54 pm
Likewise.........
 Post subject: Aye....
PostPosted: Sun Mar 04, 2018 10:42 am
Use a Duraboot stretchy boot but fit it without stretching it
Thanks for posting this Jod.
Users browsing this forum: No registered users and 9 guests
