It is currently Tue Apr 23, 2024 1:41 pm
 Post subject: Wiring diagram
PostPosted: Mon Jul 09, 2018 8:08 pm
there's two fuses in a dolomite, is one permit 12volt and the other ignition supply , also for the heated rear window should there be a relay
Thanks Dave
 Post subject: Re: Wiring diagram
PostPosted: Mon Jul 09, 2018 8:24 pm
Dolomites don't do relay's. Pure good old amps through the switches.
PostPosted: Mon Jul 09, 2018 8:39 pm
Yes, one is permanent the other is through the ignition switch. There should be relays on a lot or circuits...but there wasn't from the factory.
1997 TVR Chimaera 450
PostPosted: Mon Jul 09, 2018 8:44 pm
Thanks Mart and Jeroen
PostPosted: Mon Jul 09, 2018 8:49 pm
Relays need more cabling and cause connecting confusion on the assembly line, thus a reason to strike, easier to buy high amperage expensive dc switches.
PostPosted: Mon Jul 09, 2018 8:51 pm
And when things go wrong a fire means a new car. Good marketing strategy. :lol:
PostPosted: Mon Jul 09, 2018 11:31 pm
I still think of relays as a novelty, and I'm not that old, as all the cars I had growing up never had relays or if they did it was just the one like for the horn.
Mr Lucas has been a tad unjustly maligned, just as with any other, at the time ubiquitous, mass producer of product they build and deliver to a cost. Could be worse, like the Magneti Marelli stuff I've encountered in years gone past!
PostPosted: Tue Jul 10, 2018 10:27 am
It's very hard to make exact reproductions of Italian harnesses. It's almost unnatural to fabricate because I'm always tempted to improve because that's so easy to do.
Users browsing this forum: Bing and 39 guests
