It is currently Wed Apr 24, 2024 4:29 am
 Post subject: power steering
PostPosted: Sun Aug 26, 2018 9:50 pm
i have a 1500 fwd that has a rather large steering wheel. as the wheel on the dolomite range is smaller i was wondering if they had power steering?
 Post subject: Re: power steering
PostPosted: Sun Aug 26, 2018 11:18 pm
None of them did from the factory but I've read a couple of Vauxhall Corsa electric steering conversion posts here.
 Post subject: Well….
PostPosted: Mon Aug 27, 2018 9:56 am
Dolomites (save for the early 1850s and some early Sprints) had a lower ratio steering rack
thereby meaning less effort is required, hence the smaller steering wheel.
PostPosted: Mon Aug 27, 2018 10:27 pm
This Corsa PAS convo only works on cars with auto trans, as the motor occupies the space normally used by the clutch pedal assembly!
There now appears to be a EPAS kit in varying degrees of DIY, or a factory fit option, for ALL models of Dolomite. But it is MEGA expensive (£2k upwards) as it includes a mass of bespoke parts, all of which are safety critical. Think it may be made by a Dutch company, but assume they have at least one UK outlet. At least one club member has had it done, but I can't remember off the top of my head, who it is!
Users browsing this forum: DotBot [Bot] and 47 guests
