It is currently Fri Nov 16, 2018 10:23 pm
Post new topic  Reply to topic  [ 96 posts ]  Go to page Previous 13 4 5 6 7
PostPosted: Sat Oct 06, 2018 7:30 pm
Enjoyed having the Dolly out today for the (probably) last time this year.
It’s a shame Castle Combe Autumn Classics was a wash out!
PostPosted: Mon Oct 29, 2018 6:55 am
A sunny Autumn drive - maybe the last of the year.
I have also purchased a 1850 donor car with over drive that I will be using for my 1850/TR7 engine conversion I’ll be doing over the winter.
The car is a barn find so the rest of it will be for sale once I have used the parts I need.
I will also have a 1500 engine & gearbox for sale once removed from my car.
PostPosted: Wed Nov 07, 2018 12:22 pm
So,
After a bit of a disaster going to collect an 1850 that i won on ebay (Arrived to find it was actually a 1300!!) and a wasted trip to Reading.
Dan Brown came to the rescue & sold me his russet brown Dolomite 1850 with Overdrive & kindly delivered it to my house.
I will be stripping the car over the next coming weeks to a bare shell. I have a feeling the engine may be seized so i need to look into whether i should rebuild the 1850 lump before fitting it into my 1500.
Looking for peoples opinions on rebuilding the 1850, Is there anything to be aware of before i start?
PostPosted: Thu Nov 08, 2018 5:59 pm
If the engine is already out of the car, I'd definatly do the engine bearings and thrust washers and inspect the bores, maybe deglaze the bores and re-ring the pistons. Inspect the timing chain tensioner while its out. Then if the crank needs a regrind I'd go for balancing as well; maybe a rebore... Its a bit like eating salted peanuts. You can never eat just one.
As regards difficult bits, the crank pulley can be very tight, the water pump can be difficult to remove and the head studs can also be seized. Get back to us if the head is stuck as we have a solution. One other thing we found on an 1850 we worked on last year was that the flywheel had been put on 60 degrees out. :shock:
PostPosted: Sat Nov 10, 2018 9:11 am
Slight change of plan over the weekend:
* I have been making a lost of everything that would need to be done to carry out the 1850 conversion on my 1500. The list was substantially longer than i first thought it may be, My 1500 is near perfect & it would be a shame to put a 'non-perfect' engine & gearbox in it.
After factoring in costs of rebuilding the 1850, Rebuilding the OD gearbox + replacing all the coolant hoses, Radiator etc etc etc i have decided its going to cost a lot more than i can afford at the time being.
So the new plan is to refurbish the engine bay & engine of my 1500, Plans are:
- Try and source a 1500 Overdrive gearbox.
- Remove engine from car & replace sump gasket, Clean block/head/rocker & paint.
- Replace clutch & slave whilst out.
- Clean up & paint engine bay whilst engine removed.
- Tidy up wiring loom etc whilst engine out.
- Replace complete exhaust system with stainless.
I would like to do some mild tuning to the 1500 engine but it seems more hassle than its worth so i think ill just keep it as it is.
** (If anyone is interested in any parts from my 1850 then let me know) **
PostPosted: Sat Nov 10, 2018 11:22 am
Don't forget the prop shaft.
Whilst you have the engine out it may be worth do some basic porting. I understand the club are doing a 421 manifold so that would go together nicely.
If I were to go for a manual dolomite it would be a 1500 with over drive.
