It is currently Fri Nov 16, 2018 9:51 pm
Post new topic  Reply to topic  [ 2 posts ]
 Post subject: Clutch
PostPosted: Tue Oct 30, 2018 8:17 pm
Hello all. I am rebuilding a Sprint engine for fast road use. I am having the bottom end lightened and balanced along with the pistons and con rods. I have a fast road cam and a good rebuilt head ready to go. But my question is do i need to use a heavy duty clutch and if so where do i get it ? I estimate the power to be approx 140 bhp so will a standard clutch do the job ? Any advice is most welcome. I am also having the flywheel lightened by 5/7 lbs.
 Post subject: Re: Clutch
PostPosted: Wed Oct 31, 2018 12:11 am
A standard clutch will be fine for that amount of power. You can actually get more power than that from a standard Sprint engine if built properly. What carbs will you be using?
2007 Porsche Boxster S
Grammar:
Schedule: Pronounced "Shedule" not "Scedule"!
