It is currently Sun Apr 28, 2024 5:27 am
PostPosted: Wed Mar 20, 2024 8:21 pm
Will soon have the Dolly under cover and will in a position to remove the windscreen and rear screen to replace the torn headlining. Before I do this I wanted to get recommendations on which was the best lining to buy?
Also while I have the lining out I am going to checkout the roof, still have a leak into the passenger footwell, which despite all my best efforts I cannot beat. After eliminating everything else the only thing I can come up with is some hidden rot in the roof which is allowing water in.
PostPosted: Wed Mar 20, 2024 8:32 pm
Before you strip any thing out get a smoke machine off E Bay you should be able to find any leaks
As for headlining, i thought they all came from same place, are you going to fit it yourself
PostPosted: Wed Mar 20, 2024 8:55 pm
Got mine from Newton Commercial, it has been professionally fitted.
PostPosted: Wed Mar 20, 2024 11:01 pm
'Longhorn' is the original pattern, I believe...
PostPosted: Thu Mar 21, 2024 8:44 am
Yes the Newton one uses the Longhorn material.
https://newtoncomm.co.uk/collections/do ... headlining
PostPosted: Fri Mar 22, 2024 8:24 pm
I have found that one way water can get into a dolomite is via the roof gutters. When the cars were built the roof was one side of the gutter and was sealed into part of the gutter and this seal breaks down with age and this allows rain water to find its way into the front foot wells and the boot. To find out if your problem is this joint can I suggest you cover the gutter with masking tape and then see if you get water in the car when it rains hard. See photo of my red car 's roof gutter covered in masking tape.
It is very difficult to stop this leak and I am considering just filling the gutter with silicon sealant.
PostPosted: Fri Mar 22, 2024 8:37 pm
I have just found Tony Burd's photo which shows the arrangement of the roof / gutters and you can see if the water gets from the gutter to the inside there is another gutter like path for it to flow along to both the front and rear of the car depending on how level the car is.
 Post subject: Aye,....
PostPosted: Fri Mar 22, 2024 9:00 pm
I believe the inside sections are called cantrails (or should that be cant-rails?)
Their primary purpose is to act as a bodyshell strengthener
A good thing about ye olde fashioned Dolomite gutter arrangement is that it protects the doors from above
so in the winter no snow falls onto the seats upon opening the doors :D
Ian
PostPosted: Fri Mar 22, 2024 11:39 pm
Another often neglected spot for water entry is around the rather hard rubber seals that surround the wiper spindles, the water then fills the box section below the screen, rotting it in the process (almost invisible till the dash crash pad is out) and finally running down onto the floor.
Because, at least at first, the box below the screen frame is closed off except the ends, most of the water that enters here runs down the A posts behind the trim and you don't see it till it soaks the carpets.
I have a NOS cantrail section (N/S IIRC) if anyone is interested.
PostPosted: Sun Mar 24, 2024 12:02 am
Thanks for the suggestions but I don't think you know the lengths I have gone to find this leak. I stripped out the entire interior and removed the screen. Went from top to bottom to find every possible rust hole and welded them up. I have also fixed the potential leak from the wiper spindles and fully sealed the screen.
In my defence I beat the leak into the drivers side but not the passenger side. Somehow it is still getting in. Which makes me suspect something is up with roof. Could be the gutters but I resealed the entire length of those as well.
Users browsing this forum: Google, Majestic-12 [Bot] and 2 guests
