File comment: leaving the circuit on the 2nd of 3 barrel rolls
This is what happens when a brake hose lets go at 110mph at the end of the fastest straight at Hampton Downs race circuit! Dual circuit Sprint master cylinder was of no help as the pedal went straight to the floor.
As I as trying to outbreak a Celica at the time and was deep into the corner, I had no option but to try to get as far round the corner as I could, get the car sideways to scrub off speed and not hit anything head on. Gravel trap worked well, as did the tyre wall and the in car safety stuff. I walked away without even a bruise, just sore muscles each side of my neck. Car however is a total wreck, twisted and bent in all directions, especially the roof, mainly around the full cage. Without that I probably wouldn't be writing this.
Now looking for another bodyshell to start again. All the drivetrain appears undamaged and working.
Rubber part of the hose (right front) came clean out of the crimped end. No sign of wear or damage. Worked well in previous corner, also a right hander, nothing in this corner at all. Hose had been on the car with the same brake and suspension set up for about seven years. Inspected prior to the race meeting and after the accident. Scary stuff as these are the same parts we use on our road cars as well.
Will try to get the full sequence of picture into Dolly Mixture.
Geoff
