Hi,
The party is over It's time to call it a day, it time to play,
With the Dolly!!
Todays plan was to see if it was possible to get any life from the engine.
To see if I could get it turning, firing, and maybe even 'running'.
We took the bonnet off, this gave us a lot more room to work on the engine.
Took the plugs out and injected oil into the bores.
Turned the engine over by hand, turned very easily and freely.
Then fitted new plugs.
Took the carb dashpots and float chamber tops off.
re-set the jets, at the right hieght,
Freed off the choke mechanism.
Loads of WD40 every where.
Blew out the flaot chambers and inspected the float assemblies.
All in excellent condition.
Dashpots though were a different affair.
Seized solid
Had to use heat to free them off.
Took our time and managed to get them nice and smooth.
Filled the dashpots with oil,
re-fitted the float chamber tops,
Fitted a temp battery,
and managed to get it cranking.
Rigged up a temp fuel supply,
got fuel pumping through the pump,
So pumped fuel into the float chambers
ready for a spark
Dist cap looked fairly new,
as did the points and condenser.
Checked the gap which was out.
So, re-gapped the points,
Re-fitted the cap and all leads etc.
And went for a start up.
Cranked a while firing but not catching,
Then........................
Away she went.
You can't see it in this shot, but she is running.
Sounded great.
Stopped it, I only wanted to hear it run first,
Now was time to check the cooling system
Two top most hoses were split.
So we managed to 'bodge' them so they didn't leak,
Enough so that we could run it up to temp, just to check the motor properly.
They held water quite well. The cooling system had only lost a small amount whilst standing all them years.
The car will have a full set of hoses fitted before it goes anywhere.
Any way. Re-started the engine, and this time allowed it to warm up to temp.
The engine didn't sound good....................................................
It sounded bloody brilliant. One of the sweetest sounding engines I've ever had the pleasure to own.
Stu from Oz was dead right when he said it's good when you find things are better than you thought.
it really makes you get on and feel good about the whole project. Even though I am still right at the beginning.
Now making a list of all the items I am going to replace on the engine itself so i can move on to the next 'system'
This what the N/S wing looks like
I got carried away and got the polish out,
and polished the O/S wing
Only polished the top and the inner wing slightly,
But the colour came straight through.
Looks gorgeous.
The colour code is HAE. Does anyone know what it is called?
So I am feeling quite good now. The first high point in the restoration.
Where next?
I'll keep you up to date.
Martin.
