Drilling the Waxstat Capsule on the bottom will drain the wax and as result it has the same effect than the 2 penny conversion.
http://www.dunlopclassics.co.uk/waxstats.htm
https://forum.retro-rides.org/thread/22 ... bay?page=7
people in other forums are reporting that its a small mess when the wax is flowing out.
but i cannot find any pictures.
i drilled a hole from the bottom, completely through the capsule....but nothing was flowing out...the only debriss / metal filings i had, were from the copper-capsule.
watching through the drilled hole i could neither see a chamber where the wax could have been located.
even i understand the general principle, i dont understand the dedicated-principle after what i recognized above:
there is this copper-capsule, looks like a turned-workpiece, made of solid copper.
how this capsule expands? where is this so called "wax"?
what i also recognized is: why the 2 penny conversion, leaving the spring inside the jet?:
the spring could be removed and replaced by some washers, same thickness as the compressed spring, than the copper-capsule, with "drained" wax (where-ever the wax is located) . no messing around during assemly with jumping-out pennies due to the spring-force.
