I would draw your attention to again to this part of my post!
Since I know you have some sort of TJ style vented disc conversion, I would simply point them out to any smart assed tester who wants to condemn your lack of an LSV. Fit TJs (or reasonable facsimile) and the need for an LSV evaporates!
Surely doing the job properly would be repairing the valve and refitting it?
If a car was brought back to me with the valve removed after I'd failed it for being seized or leaking then I'd fail it again, as above "removed when it's fitted as standard equipment".
It's there for a very good reason on a Sprint and shouldn't be bypassed.
Bad advice imo.
The post itself was aimed at Dave in particular, not people (Sprint owners) in general.
I'm more than aware WHY a standard Sprint has an LSV fitted! I could make a good case for "doing it properly" being replacing the LSV with something that actually WORKS for more than 5 mins before seizing up!
I have a large and growing collection of Sprint LSVs, all of which were removed seized solid. I can't recall EVER seeing one working as advertised.
I feel perfectly entitled to do away with the troublesome LSV because ALL my cars have the Trackerjack conversion that obviates the need for the LSV. As I'm sure you (and the vast majority of readers here) know well enough.
I ran the Carledo on stock Sprint brakes sans LSV when first built and found out the hard way that it's a bad idea! So MY first move was to seek an LSV. When I couldn't find a working one for love or money, I fitted a Cavalier pressure limiter which fixed the problem. Then I went to TJs and the problem went away.
Now I've been a tester myself, I can understand your point. If someone presented a stock Sprint to me with the LSV seized, I would fail it. If they re-presented it with the LSV removed or bypassed, I would fail it again! But, if they presented or re-presented it with TJs and no LSV, i'd pass it happily!
Were I a "normal" tester and not a Dolomite nut, I'd behave the same way, Except if the car had been redesigned without the LSV but looked standard otherwise, I probably wouldn't know any better! It's quite easy to spot something present but not working, much harder to realise something is missing when you don't KNOW it should be there and it's absence is carefully concealed! Which is why I do it so carefully, it's not necessarily to bend the rules, it just saves a long discussion, possibly even involving the ministry.
Rules are rules, but a degree of common sense is also required to make a good tester.
