If it's the same as a Dolomite, there are 3 short section under the car, 1 near the tank outlet, a second roughly below the rear seat and a third to the rear of the front footwell. All these are 5/16" (8mm) as are the 2 longer hoses into and out of the fuel pump. If you have a TC 1300, the hose into the carbs is 5/16" and the pipes between are 1/4" (6mm). If it's an SC, I think the final hose into the carb is 5/16" also, but I wouldn't swear to it.
_________________ '73 2 door Toledo with Vauxhall Carlton 2.0 8v engine (The Carledo)
