Advice on some bits....
This is all kinda circular but as I'm getting there I need my memory refreshed...<br>
I need a brake bias valve. Now, I hear that the knob type would be better (more adjustment). Any recommendations? Don't really want to spend more than 50 quid <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
Also, I need a set of s/h lowered & uprated springs, maybe even shocks. Anyone got any lying around?<br>
Is the Jigsaw steering UJ the only one that fits or does the Rally Design one too? I tried to order one from Jigsaw but they didn't have any last time.<br>
I think that's all. <glum> Gonna have to uprate the brakes, they're useless. 1500 master cylinder and servo, single circuit, bout as good as sticking my foot out the door.<br>
Any landy M/cyls that drop in? Or anything beefier? <br>
Going to be rebuilding the axle and brakes this weekend...joyous. Oh, and the rack.<br>
Anything appreciated...taa <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
Re: Advice on some bits....
Yes the Rally Design one fits but I can't remember the part no. I didn't realise Jigsaw had started selling these as well.
<p>Martin<br>
<p>Martin<br>
RD820 Steering Coupling Group 4
<p>1980 Dolomite SprintV8 (Soon to be shoehorned with a 360bhp of TVR AJP V8 Pumping Alloy !)<br>
They laugh at me because I am different. I laugh at them because they are all the same!)<br>
http://www.triumphowners.com/310 </p><i></i>
Ta muchly <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
I'll be on the road come next Friday, hopefully! I'll have to come down for a little blat <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Re: ...
Couldn't get me one at the same time could you Lewis? <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> I want to put one on my Brooklands Sprint
<p>Martin<br>
<p>Martin<br>
Damn, about 20 seconds too late! Just ordered it <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
I'll tell you how I get on with it. Probably find the bar-steward won't fit properly knowing my luck <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END-->
Re: ....
It should fit ok. Mine did, but I know others had trouble. I had to cut off ½" from the end of the shaft but others say they didn't. Strange phenomena. Someone was sent a cast one but I think that was just a one off, it should be pressed steel.
<p>Martin<br>
<p>Martin<br>
Re: ....
I've got a 1" bore willwood brake master cylinder you might want to take a look at. Mounting holes are 90 degrees out compared to standard sprint but I'm sure there is a way around that. Its a single curcuit master cylinder. <br>
The tilton brake bias adjuster is fine, knob or lever. Knob is probably less intrusive and as you say has finer adjustment. <br>
By the way, the guys at the rolling road near you seem alright. Cost me £125 for 2 and a bit hours of work on carb adjustment, timing and a a couple of power runs. I got the feeling that they are not into doing a full rejet but if you are happy that your carbs have had the right jets in from the off then I would recommend them.<br>
Strange as it seem's
A larger master cylinder bore will actually give less pressure.<br>
(More area mean's less pressure Dont ask me how it work's)<br>
I over came this by moving the pivot point on the brake pedal.<br>
Willwood 1 1/16" on the V8.<br>
<!--EZCODE AUTOLINK START--><a href="http://www.carbibles.com/brake_bible.ht ... <!--EZCODE AUTOLINK END--><br>
3/4 of the way down explain's
http://www.triumphowners.com/310 </p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... printV8</A> at: 25/5/06 10:31 pm<br></i>
Re: Strange as it seem's
Yer its all about leverage isn't it.<br>
say the standard master is 1/4 the size of the wheel cylinders then the pressure is multiplyed by 4. So 10 kilo on the master (not the pedal, thats levered again<!--EZCODE EMOTICON START :b --><img src=http://www.ezboard.com/images/emoticons/tongue.gif ALT=":b"><!--EZCODE EMOTICON END--> ) is 40 on the cylinders.<br>
A bigger master say 1/2 the size of the wheel cylinder will multiply the pressure by two. But! You'll have less pedal travel <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
