blue exhaust smoke
Locked
denis thompson
blue exhaust smoke
#1 Post by denis thompson » Tue Aug 08, 2006 5:51 pm
I wanted to ask if I can get some info on why my sprint now and again emits blue exhaust smoke. I just returned from a triumph run into the US and did 2000km and used no oil and no one complain of any smoke following me. It only happens now and again at traffic lights or having to wait at the border back into canada<br>
Denis
Dolly racer 33
Blue smoke
#2 Post by Dolly racer 33 » Tue Aug 08, 2006 10:50 pm
Sounds like valve guides/stem seals. However, before you rip the engine to bits, check your servo/master cyl seals. You would only need a very small amount of oil down the valve stem to cause blue smoke. The reason you only get the blue smoke on idle is because the throttle butterflies are closed & there is a greater vacuumn in the inlet tract therefor drawing a small amount of oil down the guide.
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... er33>Dolly racer 33</A> at: 8/8/06 10:51 pm<br></i>
denis thompson
Re: Blue smoke
#3 Post by denis thompson » Wed Aug 09, 2006 4:52 pm
Thanks I will check that out first as that is easier than taking the engine apart.<br>
Denis
2F45T4U
Re: Blue smoke
#4 Post by 2F45T4U » Thu Aug 31, 2006 2:28 am
if it is the guides you'll get quite a bit on over run, drive behind your car whilst someone else is driving and get them to slow down through the gears
Locked
