Does anybody here....
Locked
2F45T4U
#1 Post by 2F45T4U » Thu Aug 31, 2006 4:38 pm
.....have the burden of a Fiat Punto upon them?<br>
Two of my mates have them, how the hell do you adjust the hand brake?!
LewisK
Re: Does anybody here....
#2 Post by LewisK » Thu Aug 31, 2006 4:41 pm
What year?
2F45T4U
#3 Post by 2F45T4U » Thu Aug 31, 2006 4:41 pm
95 and ermm 98. 2 shapes ago <!--EZCODE EMOTICON START :b --><img src=http://www.ezboard.com/images/emoticons/tongue.gif ALT=":b"><!--EZCODE EMOTICON END-->
1300dolly
#4 Post by 1300dolly » Thu Aug 31, 2006 4:43 pm
no but it did break one last night in an attempt to fix it, before the owner , who also owns a dolomite powered spartan kit car, said 'oh i think its under warrenty still'.<br>
nope aint got a clue how to adjust the handbrake.<br>
J.
LewisK
#5 Post by LewisK » Thu Aug 31, 2006 4:46 pm
Well the Punto has rear self-adjusters so you probably need to wind them out to compensate for the wear on the shoes?<br>
If you get underneath the car the adjuster is just behind where the handbrake comes through the floor and this can be used to take the slack out of the cable, if there is any <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
Should be 4 clicks on the ratchet standard, I think. <br>
If it's just happening as a result of a recent cable change, there was a bit of an issue with different length cables a while back...<br>
<!--EZCODE QUOTE START--><blockquote><strong><em>Quote:</em></strong><hr>To adjust the cable you turn the small 'key' bar clockwise to tighten the cable and anti clock wise to loosen the cable. Using a decent set of pliers or a shifting spanner should give enough hold to turn the 'key'<br>
Note that you don't need full access to the turning of the key as only a small few turns are usually ever needed to adjust the cable properly. If your cable needs a lot of adjustment I'd recommend a new cable coz it's obviously done.<hr></blockquote><!--EZCODE QUOTE END-->
<!--EZCODE FONT START--><span style="font-size:xx-small;"><!--EZCODE ITALIC START--><em>Crazy! I mean like so many positive waves, we can't lose! You're on!</em><!--EZCODE ITALIC END--></span><!--EZCODE FONT END--></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... >LewisK</A> at: 31/8/06 4:50 pm<br></i>
dollysteve
#6 Post by dollysteve » Thu Aug 31, 2006 4:48 pm
If you let me know what year it is i`ll take a look in the workshop manuals, we have the proper fiat ones in the library. From memory though the only adjusment is on handbrake travel, this is adjusted via a nut under the handbrake lever, you`ll need to slide the gaiter out the way first.
alun n
#7 Post by alun n » Thu Aug 31, 2006 8:09 pm
I bet their rear lights don't work very well; crap, even by Italian electric standards. I understand it was one of the reasons for the redesign...
2F45T4U
#8 Post by 2F45T4U » Fri Sep 01, 2006 1:46 am
Yer Alun your right! One of them has only one brake light and the other had one much brighter than the other.<br>
There crap cars, absolute sh1t. And these boys wanted these cars! One of them has a 1.1 (55hp) and the other a 1.2 (60hp), the 1.1 is so slow my car would hold it off if I pulled away normally! He wouldn't come out driving with me cos I was to fast for him <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> <br>
FWD, small engined, PITA to work on, twice as expensive to buy...<br>
Why ever did I buy a 1.8/2 litre, RWD car from the 70's? <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
george
punto
#9 Post by george » Fri Sep 01, 2006 1:49 am
if you have the silly springs with fibre washers <br>
iv'e always reversed the car and braked heavy this <br>
is suposed to be the way to adjust them<br>
it usually works (it has on the ones iv'e done)
2F45T4U
Re: punto
#10 Post by 2F45T4U » Fri Sep 01, 2006 1:54 am
using the foot or hand brake?<br>
Is your middle name Haynes? <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
george
brake
#11 Post by george » Fri Sep 01, 2006 1:57 am
foot brake
2F45T4U
Re: brake
#12 Post by 2F45T4U » Fri Sep 01, 2006 5:19 pm
Mildly better. Had a go of his car today, you can lock one of the wheels in reverse with the hand brake but sometimes it doesn't hold you on hills.<br>
george
mildly
#13 Post by george » Fri Sep 01, 2006 11:40 pm
did you slack off the h/brake cables first
2F45T4U
Re: mildly
#14 Post by 2F45T4U » Sun Sep 03, 2006 2:08 am
there a bitch to get at, I can see an adjuster mechanism under the hand brake gator (one of the boys cars has his gator ripped) but you cant get at it! Looks like the cables need to come off then the adjsuter twisted a few times then the cables hooked back on.<br>
I've also got the keys to a Fiat Tipo that the owner wants me to find out why its got dodgy brakes and clutch... Other than an X1/9 I'd ever consider a Fiat!
algtj
Re: mildly
#15 Post by algtj » Sun Sep 03, 2006 9:26 am
Barchetta's are nice! <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> Albeit on a punto floorpan! <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Locked
