1st week of ownership
Stripped her down and ..well she's in a lot worse condition than I first thought. Found that most of the front, rear and many other bits are filler. The chassis leg thingys now have lots of holes in them after I decided to have a prod with a screw driver and the bits of the car that aren't rusted consist of weld upon weld.<br>
I direct this next question to those of you who may know of a cheaper source of parts than ri**er & friends.<br>
Do I attempt to painstakingly rebuild her spending a fortune on panels or do I risk buying another dolly and transfer all the good bits across. The good bits being bootlid, bonnet, engine carbs spax, newish springs etc. Basically all the running gear is sound. Do dollys with good shells and knackered running gear etc exist? It always seems to be the other way around.<br>
Re: 1st week of ownership
Just noticed a cheap 1300 for sale near me. Apart from the subframe and the obvious stuff is there any difference between the shells?
Neil Russell
Good shells
You have fallen into the trap that magatsu will soon plunge into.<br>
you have bought your car and found that the front and rear jacking points are crusty, the sill section middles where you prodded are probably sound, only the front and rear ends seem to rot, the upper inner wing strengtheners are probably also crusty, along with pieced and filled rear arches and various underfloor sections.<br>
If you have been really unlucky your front scuttle will have succumbed too.<br>
Don't loose too much heart. go to your local club meet. sills are easy to fabricate and the outer skin sections are readily available. the only pain with a dolly is having to cut the wings off to repair properly the sub structure.<br>
people tend not to want to pay lots for project cars (read magatsu's thread elsewhere) and as such find themselves sooner or later doing the work to the car which they all need. <br>
stick with your car and repair it. because you aren't going to find much better in another 25 year old shell.<br>
this is why rust free shells are advertised for £4000. look at it this way. if you properly restore a car with a brand new shell costing you say £6-9 k if you really want a car of this type, its still alot cheaper than going out and buying a mondeo etc.<br>
if you can do it yourself then all the better, it just takes time. <br>
Go out and buy a good welder and argoshield kit from BOC then teach yourself. you will be surprised at how easy welding is. just take your time when fabbing the bits and only weld when everything has been ground down to shiny metal. people only struggle to weld coz they hurry or try to weld rust and paint.<br>
good luck and may the force be with you.<br>
Neil.<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Yes but...
There is a lot of truth and experience in what Neil says but it is possible and a lot cheaper to source a good Dolly shell from a late 1300 or any other model. You just need to be patient, look hard and buy from some old boy who's had it garaged from new.<br>
You will have grief fitting the front lights if you get a low rent one and a Sprint also has a unique sub frame and the engine steady bar. Lots of previous threads on this subject so I wont bore everyone with more.<br>
Re: Yes but...
Well I've ordered the rimmer catalogue, I'm going to strip everything off and work out how much it'll cost me, if its too much I'll have to go for the second donor car and nick the shell (idealy one with the round lights save me having to fart around too much :P).<br>
I would like to rebuild it from scratch but I haven't got £6-8k spare and I want to try and get this car up and running in a about 6 months to a year. Then after I get used to the power it's time for a V8, cos I love the sound <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> .
Well you can check the cills,subframe and common rust spots pretty easily. Lack of any welding is also usually a good sign. Besides the car I have now was bought on the assumption that it would need a fair bit of work, it was half stripped and sprayed in a lovely colour scheme of yellow and grey primer with hammerite instead of the vinyl roof.<br>
Unfortunately for me it looks like it needs more attention then I first thought (I don't mind a challenge but this car needs to be brought back from the grave)<br>
Basically the point I'm not making is that I can't do anyworse than spend £500ish on a car that has been regularly used and maintained that shows no obvious signs of any major corrosion. Even if it needs a few panels replacing its gonna be a damn sight cheaper than replacing all of them. Plus I'll get the interior to boot <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END--> .
Uh-oh
just like to have my say <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END--> , what ever you do dont lose heart, which ever way you decide to go, i for one didnt pay thousands for my car, i got a 1976 1500hl for £50, which is totally solid and was given a sprint free that had more hole's in it than metal, its taken a time to do but ive swaped everything over and just finished respray so she looks real nice,all thats left is vinyl roof <!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END--> <br>
and i was also wondering about advertising on this board!!! seems certain people can get away with it <!--EZCODE EMOTICON START :evil --><img src=http://www.ezboard.com/intl/aenglish/im ... /devil.gif ALT=":evil"><!--EZCODE EMOTICON END-->
triumphdolomiteuk
- Site Admin
Re: Uh-oh
Any blatent advertising will be removed from this board,no matter who posts it.Everyone knows the rules,it's not just the Club being petty,there are practical reasons as to why we don't allow adverts on here.If adverts do occasionally slip through,it's because I don't always have the time to monitor the forums or because it's borderline as to whether the post constitutes an advert.I like to think I'm a pretty easy going chap and so I usually give people the benefit of the doubt.<br>
Our <!--EZCODE LINK START--><a href="http://www.triumphdolomite.co.uk/sales&wants.html" target="top">Sales & Wants Pages</a><!--EZCODE LINK END--> are regularly updated (often two or three times a week) so there really is no reason to post adverts on here.<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
-Andy.<br>
-Andy.<br>
Chris Field
Oooooh don't......
You're worrying me now!<br>
My first week of ownership has consisted of locking it in the garage and not having time to look at it since due to domestic commitments. Keep on like this though & I'll be too scared to look closely at it!<br>
Good luck!
Good luck!
Welding
I've decided to try and repair the one I have as opposed to buying another one in better condition and swapping the bits across.<br>
My main concern is welding the new bits onto the old bit. Wings and door skins etc I'm not to bothered about but any tips on how to weld new chassis arms with a mig would be most appreciated.<br>
One last thing any recommendations on a suitable make model of mig.<br>
Re: Welding
Mig<br>
Pay more and get a proper unit that will last. SIP, Cebora, Otter or Oerlikon will do well. Buy a Clarke one from Machine Mart and live to regret it. A proper one will be a joy to use. Also, there is no need to buy one that takes a large reel of wire. Unless you are doing production welding / fabrication the long wire reel will be rusty and of no use before you have used half of it.<br>
Jod
Jod
Re: Welding
So the Nutool ones are out of the question <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> .<br>
What is the minimum ampage you would recommend and how much difference does the gas actually make?<br>
How were the original chassis arms attached, they don't appear to have been spot welded like all the other bits?
Welding
My crappo Clarke 100 works just fine, and was the cheapest thing around here (65 quid s/h - SZure they're half that up north..). Sure, it blows holes and feeds wire far too quick at anything over the lowest setting, and randomly goes from good to bad back to good welds on the same bit of metal, but still...<br>
Actually, thinking about it, maybe it is a load of crap after all!
Re: Welding
What about the 'no gas' MIG welders? Sounds like a contradiction to me (MIG = Metal Inert GAS!!)
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--></p><i></i>
