Clutch Hydraulics
Locked
Kootara
Clutch Hydraulics
#1 Post by Kootara » Sun Oct 30, 2005 9:02 pm
1978 Dolomite 1300 RWD.Just fitted new Master and Slave together with non flexible pipe.Have bled a few times.System works ok to start with.Next day less pressure,have to double de clutch to get into gear sometimes.Reverse almost impossible without lots of pumping.Fluid level OK.Anyone any suggestions.<br>
John Wood.
DailySprinter
clutch hydraulics
#2 Post by DailySprinter » Sun Oct 30, 2005 10:13 pm
Somewhere you've got a leak, even new cylinders are not always perfect espacially if they have been stored for a long time. You should find fluid leaking somewhere.
Second that...
#3 Post by Jon Tilson » Mon Oct 31, 2005 10:35 am
and to remind you that the bleed screw must be above the inlet pipe at the slave end, else you cant get rid of that last bubble...<br>
Kootara
Dolomite Clutch Hydraulics
#4 Post by Kootara » Tue Nov 01, 2005 5:11 pm
Many thanks for the info,will check that outRegards John
Locked
