Sprint fast road engine rebuild
davepoth
Re: True...
#16 Post by davepoth » Fri Aug 18, 2006 11:54 am
I for one don't want a melted engine. But that does clear up a lot of stuff about lean burn for me. Probably makes sense to just make sure the spark you have can do its job properly. <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
tinweevil
Re: True...
#17 Post by tinweevil » Fri Aug 18, 2006 12:53 pm
Jon, the point you are overlooking is that you are thinking of the spark you have seen at low revs. As you say the standard coil produces a perfectly adequate firelighter. However, at 5000 rpm there roughly a tenth of the time between discharges for the coil to build a nice stable field. Up there the spark can be quite weedy. The quality of a coil will affect the speed at which it can build it's field and the stronger the field the greater the power generated when it collapses. You have 3 times the problem on a V12 which is why <!--EZCODE LINK START--><a href="http://www.vintageperformance.com/" target="top">pertronix</a><!--EZCODE LINK END--> (Aldon in the UK) rate their coils by cylinder.<br>
Needed for normal daily driving? Probably not but this is a fast road engine thread. Scott has the best possible proof of the benefit.<br>
Tin
Absolutely...
#18 Post by Jon Tilson » Fri Aug 18, 2006 1:48 pm
and jod's electronics and similar efforts do gve much better sparks at higher rpm.<br>
Sorry if I seemed to miss that point in this debate but there you go....<br>
Its also far worse on multi cylider engines, which is why most V8's and V12's have twin coils.<br>
Jonners<br>
Locked
