Page 3 of 3
Manifold / Roll bar
Posted: Thu Oct 02, 2003 5:42 am
by Stephen Grellet
The new roll bar has the advantage of solid mountings which will make the bar operate better. In regards to the pick up point, the bars effective stiffness is the bar stiffness multiplied by the motion ratio squared. The motion ratio is the distance from the pick up point to the pivot point (bush) divided by the total length of the bottom arm (between pivot points).If the bottom arm is 10 inches long, and the pickup point is 5 inches from the pivot point, then the motion ratio is 5 / 10 or .5 .5 squared = .25 If the bar strength at the end of the bar arm is 300 lb/in then the effective strength is 300 x .25 or 75 lbs If the pick up point is right at the ball joint then the motion ratio would be 1 and the effective strength of the bar would be 300 in/lbs
Re: Missing something...
Posted: Thu Oct 02, 2003 7:54 am
by MaddMart
Ahh! I see <!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END-->
<p>1974 French Blue Sprint<br>
1979 Brooklands Green Sprint</p><i></i>
Back to the original topic
Posted: Fri Oct 03, 2003 8:42 pm
by Richard
I've finally sent out pics of the manifold that I intend to get made up.<br>
Smifter, can you put the pics on your website, so that others can see ?<br>
It look quite simple which I guess means the flow will be good as it's not like spagetti ? the primaries look about the same length and the exit bore is huge !!<br>
As with the Sierra brakes, the more people who want one, the cheaper it will be ....<br>
RSVP......
tis done
Posted: Fri Oct 03, 2003 9:15 pm
by SMIFTER
its worth getting a length of welding rod or similar to compare pipe lengths - if they arent even it could be a waste of time.<br>
I'd be interested to know how flexible the power is with this manifold - the best setup for mid range flexible power is a 4-2-1 manifold however this one is a 4-1 which is very good for maximising high rpm power but mid range can suffer. Still its bound to be better than the cast manifold.<br>
<!--EZCODE AUTOLINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... <!--EZCODE AUTOLINK END--><br>
If you want these pics can you download them asap as I am getting a bit low on webspace and will probably have to delete them in a couple of weeks time when my site will be due for a decent update.<br>
Cheers<br>
Graeme
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--></p><i>Edited by: <A HREF=http://pub52.ezboard.com/bthetriumphdol ... SMIFTER</A> at: 3/10/03 9:19 pm<br></i>
Wot About
Posted: Fri Oct 03, 2003 9:22 pm
by Malc
the bit to connect the manifold to the Front Box, me thinks std downpipe no gonna do the job <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> do we call on alun for a length of 'flexi'
Re: Wot About
Posted: Fri Oct 03, 2003 9:29 pm
by SMIFTER
I think a 2 1/2" dia Jod Clark side exit special (with a bigger silencer!) would fit to it nicely<!--EZCODE EMOTICON START :p --><img src=http://www.ezboard.com/intl/aenglish/im ... tongue.gif ALT=":p"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :p --><img src=http://www.ezboard.com/intl/aenglish/im ... tongue.gif ALT=":p"><!--EZCODE EMOTICON END-->
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--></p><i></i>
Pardon
Posted: Fri Oct 03, 2003 9:56 pm
by Malc
I didn't quite hear you <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Re: Pardon
Posted: Sat Oct 04, 2003 3:43 pm
by Jod Clark
<!--EZCODE IMAGE START--><img src="http://www.towingandleisure.co.uk/Exhaust%20System.gif" style="border:0;"/><!--EZCODE IMAGE END--><br>
SOMETHING LIKE THIS!!!<br>
Ok, so its loud, but thats the only way to get Sprint-Beating power out of a 1500.... <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <br>
Jod
