Alternative axles
Posted: Thu Jul 31, 2003 5:56 pm
by SMIFTER
Darren - you've been a bit quiet of late.<br>
How tricky was your axle swap?<br>
I'm considering getting an axle off a Capri 2.8i Special and fitting that as they have LSD's as standard and are ratio'd for 13" wheels.
<p></p><i>Edited by: <A HREF=
http://pub52.ezboard.com/bthetriumphdol ... omiteuk</A> at: 28/11/03 4:12 pm<br></i>
Posted: Thu Jul 31, 2003 11:29 pm
by cd
I think you will find the capri axle is too wide<!--EZCODE EMOTICON START :) --><img src=
http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
Too "wide"?
Posted: Thu Jul 31, 2003 11:32 pm
by alun n
Is that physically............or mentally?<!--EZCODE EMOTICON START :lol --><img src=
http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Posted: Fri Aug 01, 2003 12:05 am
by cd
As you wish<!--EZCODE EMOTICON START >D --><img src=
http://www.ezboard.com/intl/aenglish/im ... s/grin.gif ALT=" >D"><!--EZCODE EMOTICON END-->
Re: ^
Posted: Fri Aug 01, 2003 7:18 am
by SMIFTER
Thanks for stating the obvious<!--EZCODE EMOTICON START ;) --><img src=
http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <br>
Its about 5" wider than a Sprint Axle. As standard Sprint wheels sit about 1" within the arches with a wide axle they will protrude about 1.5" each side - not too severe. I'm allowing to cut my arches and make some custom wheel arch extensions to go on. There are some obvious issues about wheel pcd's and brakes etc which can be fairly easily overcome.<br>
A wider track should give handling benefits much needed at the back end anyway and give it a more agressive look. I'm looking into other ways of widening front track to match.<br>
Darren's car has a Hilux axle - again wider than a Sprint item. I was wondering how he fitted it and if it was "just" a case of welding on the mounts from a Dolly Axle or if he's uses a totally different linkage.
<p><!--EZCODE LINK START--><a href="
http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--></p><i></i>
Posted: Fri Aug 01, 2003 8:22 am
by ALG1K
Not been on here much latley as im doing major mods to the Dolly <!--EZCODE EMOTICON START ;) --><img src=
http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> Taking all my time too many late nights.<br>
The Hilux axle is 1/2" wider each side than the dolly axle,<br>
I Welded the dolly outer mounts onto it ,<br>
The inners are up to u but i used straight bars and rose joints on the top, welded some new brackets to the body , And fit a panhared rod if you dont have one ,(much more predictable on the limit)<br>
DAZ
Re: ^
Posted: Fri Aug 01, 2003 12:22 pm
by SMIFTER
Thanks for the info<br>
So your inner tie bars are straight Parallel to the trailing arms? Interesting.<br>
I was thinking of rewelding the standard tie bar brackets but getting the location right could be tricky. I like the idea of rose jointed bars - they could be made adjustable too.<br>
I was looking at the hilux axles but the ratio would give me a top speed of about 90mph with 13" slicks!!<br>
Your wheels extend quite far - must be all in the offset of the wheels.<br>
Cheers <br>
Graeme
Posted: Fri Aug 01, 2003 5:56 pm
by ALG1K
my tie bars are adjustable<br>
I have some new crown wheels and pinions from the states for my axle they make the gearing acceptagle,<br>
My rear wheels are 10.5 " wide and they do have quite an offset
roll centre height
Posted: Tue Dec 02, 2003 10:07 pm
by Dave
Smifter, try a search on suspension roll centre height, should find the theory about angles etc. IIRC lowering the rear suspension RAISES the roll centre height because the rods are angled, and this negates some (all??) of the benefits of lowering.
axles
Posted: Tue Dec 02, 2003 10:12 pm
by Dave
The guy Richard is trying to get some info out of, who was involved with the works sprints was saying something about bedford comma cf axles I don't know why though! unless they were bulletproof ,low ratio with LSD and a straight swap which seems unlikely with a van axle<!--EZCODE EMOTICON START : --><img src=
http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END-->
