Dwell Angles and 1850 Dizzys
Posted: Thu Mar 04, 2004 5:19 pm
Okay, the person who designed the 1850 dizzy, it's location and how to change points deserves shooting and obviously never serviced their own car<!--EZCODE EMOTICON START >: --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/mad.gif ALT=">:"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START >: --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/mad.gif ALT=">:"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START >: --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/mad.gif ALT=">:"><!--EZCODE EMOTICON END--> (especially an auto....)<br>
I currently have a dwell angle (checked with 2 meters) on my points of 42 degrees, whereas book sez 39 +- 1<br>
Question, as I've forgotten the answer, what will 42 degrees do to my ignition, timing and general oooomph? (plugs and leads are new, coil okay, but it all feels a bit tired and lacklustre on driving - maybe the cold weather?) using LRP or unleaded has no noticeable effect either and I haven't been able to check the timing yet as (a) strobe light is a bit weak and (b) can't see the marks on the pulley wheel because of (a) and general crud on marking lines (must clean the oil off!!)<br>
On closer inspection also, the vacuum advance doobrey on the dizzy is a bit bent as well - angled, not straight, looks like it had a bash at some time in it's existence.<br>
Recommendations / ideas please on how to check the dizzy for proper operation and tips on how to change / reset points when you can't even see the bl<!--EZCODE EMOTICON START >: --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/mad.gif ALT=">:"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START >: --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/mad.gif ALT=">:"><!--EZCODE EMOTICON END--> dy dizzy cam to see if the points are open or not because of the weights... (no, I don't want to fit electronic in case it all goes t<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> ts up, because of the cost and as I've got plenty of spare points)<br>
I will probably have to resort to taking the dizzy off and having read previous threads, that's a pain in the posterior an' all.....<br>
Help! It's cold outside <!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/intl/aenglish/im ... /frown.gif ALT=":("><!--EZCODE EMOTICON END-->
