Load sensing valve
Posted: Wed Aug 31, 2005 9:28 am
by AdeyB
Hi all,<br>
does anyone have a Load sensing valve for a Sprint?<br>
Mine's seized and has caused the car to fail it's MOT.<br>
Are they simple to overhaul?<br>
Cheers<br>
Adey
Re: Load sensing valve
Posted: Wed Aug 31, 2005 9:36 am
by dollysteve
I think you can buy the seal kits from club stock.
<p>1976 Dolomite 1850 HL<br>
1979 Dolomite 1500<br>
1989 Mini 1340 Race Car<br>
1998 Fiat Bravo TD100</p><i></i>
Load sensing valve
Posted: Wed Aug 31, 2005 9:47 am
by AdeyB
Cheers,<br>
are they safe to re-seal? ie: once they've seized are they more likely to fail?<br>
ta<br>
Adey
Load Sensing Valve
Posted: Wed Aug 31, 2005 10:29 am
by Mike Groom
The valve siezes due to rust forming at the outer end of the housing, under the rubber boot.<br>
You can sometimes free it in situ by removing the boot and applying some D40 or PlusGas, then easing the piston rod by levering it with a pair of long nosed pliers placed around the 'shoulder' section.<br>
I did this when mine failed the MOT for the same reason, and its been working fine ever since.
Re: Load Sensing Valve
Posted: Wed Aug 31, 2005 11:21 am
by KLJ895W
I did that with mine and it got through the MoT, but when a car stopped suddenly in front of me the other day, the back wheels still locked up first. This might be more down to poor front brakes though.<br>
David
<p>1980 Sprint<br>
1980 1850HL with Sprint gearbox, propshaft and axle<br>
1972 VW Camper Van</p><i></i>
LSV
Posted: Wed Aug 31, 2005 1:39 pm
by Dolomite16V
I overhauled mine with a club kit and it wasn't bad to do, you need a large socket to undo the nut, 32mm if I remember rightly - it was covered in a previous issue of Dolly Mixture, anyone remember which one? Really just a matter getting everything de-rusted and scrupulously clean before building back up with new hydraulic seals (I used meths). I can probably find the article if you haven't got the relevant copy of DM, email me on:<br>
alex at zeller dot fsbusiness dot co dot uk<br>
if you want me to look it out.<br>
Alex Z.
Ok...
Posted: Thu Sep 01, 2005 11:32 pm
by AdeyB
Managed to douse it in plus-gas and it seems to move.<br>
Now to see if the MOT guy likes it!<br>
Adey
Re: Ok...
Posted: Thu Sep 01, 2005 11:41 pm
by MalcGE
Movement is very minimal. Hopefully, we should have rtainless sleeved units availbale in the near future.
It Passed!!!!!!!!!
Posted: Tue Sep 06, 2005 5:38 pm
by AdeyB
The man from "Del MOnTe" he say YES!!!!!!!<br>
awesome, 12 more months of Sprinting (and people staring at my car!)<br>
Adey<br>
(very happy)<br>
PS; put me down for one of the stainless jobbies when they're available!
Posted: Wed Sep 14, 2005 11:08 pm
by AdeyB
Alex, cheers for the article.<br>
Just organizing a car for over the winter so the Sprint can be garaged and have some work done (and avoid the dreaded salt!), so the article will prove VERY handy.<br>
Cheers again!<br>
Adey
Attn: Malc
Posted: Wed Sep 14, 2005 11:21 pm
by harryrc
Does the club kit include the rubber boot? Mine must have rotted and fallen off years ago.<br>
Thanks,<br>
Harry
Re: Attn: Malc
Posted: Thu Sep 15, 2005 9:13 pm
by MalcGE
No boot in club seal kit, you must be unfortunate there as i've never seen one that is not useable.
Re: Attn: Malc
Posted: Sat Sep 17, 2005 1:53 am
by harryrc
Does anyone have one going spare? I could buy a rebuild kit from club store. My current LSV has no boot on the front, so it gets quite rusted up and full of mud, etc.<br>
If you have one, you can e-mail me at trs4fun(at)att(dot)net<br>
Thanks, Harry
