Vinyl Roof replacement....
Posted: Tue Sep 05, 2006 9:05 pm
Now then, I am about to order some Vinyl in preparation for replacing the roof. I am going to ramble my thoughts in here, on how to do it, if anyone has anything to add, hints or tips, please drop them in.<br>
1) Remove chrome trim from rear screen surround, remove the roof gutter trim, pop the front screen out.<br>
2) Pull off the vinyl from rear, using a wallpaper scraper for stubborn bits.<br>
3) Sand down the roof to remove rusty bubbles and leftover of old vinyl, but keep it fairly rough to give a nice surface for the new vinyl to stick to. Give it a good wash.<br>
4) Paint the roof with zinc primer and then a Matt Black finish, so it doesn't rust until the vinyl is ready to go on.<br>
5) Start at the front, put 1" of glue on the leading edge, and press down. Put the windscreen back in (after ensuring it is straight), to hold the front edge. Tape the bits on the A pillars down.<br>
6) Apply Glue mixture (i am going to use 3M "Gorilla Snot", Al will know what I mean), mixed with MEK to make a brushable substance. Do six inches at a time, allowing five minutes for the MEK to evaporate before pulling the vinyl onto it. Smoothing as we go, and applying heat with gun as neccersary to remove bubbles.<br>
7) Repeat step six as neccersary, until the rear edge is reached. As the rear edge is done, fold that over and hold it with bulldog clips.<br>
<!--EZCODE EMOTICON START 8) --><img src=http://www.ezboard.com/images/emoticons/glasses.gif ALT="8)"><!--EZCODE EMOTICON END--> Wait 30 minutes, smoothing from front to rear with heatgun, until the glue has cured.<br>
9) Replace rear screen chrome and roof gutter chromes, trimming the sides as we go...<br>
10) Have a cup of tea and learn how to spell neccersary correctly.<br>
Does that sound about right, or have I missed anything?
